I'm trying to use ffmpeg to create MP4 files with burnt-in subtitles (from a .srt file) as described in:
https://trac.ffmpeg.org/wiki/HowToBurnSubtitlesIntoVideo
I'm having no luck. I get an output file, but no burnt in subtitles. The issue could be fontconfig.
I'm using ffmpeg on Windows 7 (64 bit), built with --enable-libass as required:
In the home directory, I added a fonts.conf file for fontconfig, and set up the relevant environment variables:Code:E:\Downloads>ffmpeg -h ffmpeg version N-69190-g6c559a0 Copyright (c) 2000-2015 the FFmpeg developers built on Jan 22 2015 03:13:44 with gcc 4.9.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab le-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca -- enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-lib modplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrw b --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinge r --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --en able-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable- libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enab le-zlib libavutil 54. 17.100 / 54. 17.100 libavcodec 56. 20.100 / 56. 20.100 libavformat 56. 19.100 / 56. 19.100 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 8.101 / 5. 8.101 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 3.100 / 53. 3.100 Hyper fast Audio and Video encoder
Then I took an example fonts.conf file from here:Code:FC_CONFIG_DIR=C:\Program Files\ffmpeg FONTCONFIG_FILE=fonts.conf FONTCONFIG_PATH=C:\Program Files\ffmpeg
http://www.freedesktop.org/software/fontconfig/fontconfig-user.html
ReplacingwithCode:<dir>/usr/share/fonts</dir>for my environment.Code:<dir>C:\Windows\Fonts</dir>
Then I tried the command:
I get the following fontconfig error:Code:ffmpeg -i {input}.mkv -vf subtitles={input}.srt -codec:v libx264 -codec:a ac3 {output}.mp4
I don't understand the issues with "invalid attribute" since I'm using an official conf file. Any help appreciated,Code:Fontconfig error: line 22: invalid attribute 'mode' Fontconfig error: line 23: invalid attribute 'mode' Fontconfig error: line 24: invalid attribute 'mode' Fontconfig error: line 80: not well-formed (invalid token) Fontconfig error: Cannot load default config file [Parsed_subtitles_0 @ 0000000004ee9f20] No usable fontconfig configuratio found, using fallback. Fontconfig error: line 22: invalid attribute 'mode' Fontconfig error: line 23: invalid attribute 'mode' Fontconfig error: line 24: invalid attribute 'mode' Fontconfig error: line 80: not well-formed (invalid token) Fontconfig error: Cannot load default config file
P.
DId you read http://ffmpeg.zeranoe.com/forum/viewtopic.php?f=10&t=318&start=20 also?
How to use flaccl in combination with ffmpeg&sox ?
By Selur in forum AudioReplies: 0Last Post: 11th May 2013, 02:19 -
hvr 2250 & game mode wintv - virtualdub issue
By godai in forum Capturing and VCRReplies: 3Last Post: 1st Mar 2013, 07:49 -
PIO Mode After Encoding & Other Stuff
By Tom Saurus in forum ComputerReplies: 66Last Post: 20th Jul 2011, 16:38 -
ffmpeg & jwplayer .mp4 problem
By mehmedean in forum Video ConversionReplies: 2Last Post: 30th Jan 2011, 11:02 -
Capture AT&T (ATT) Uverse video signal & AT&T Uverse DVR programs
By bluehan2010 in forum Capturing and VCRReplies: 1Last Post: 23rd Apr 2010, 10:40
