I have lots of video files that I want to cut. I only want a few minutes worth of video from each file. Usually I cut 5 - 6 sections from a single file. Problem with most video cutters is that they just cut once and dump everything else away. Having to do this one by one, and with 30 videos to go through is really troublesome.
Anyone can recommend video editors that can cut multiple videos from the original and export/render each as independant files? Even better if it theres queue function or scripting feature.
Any decent NLE could do this.
Either render each cut section on the same timeline separately or create a timeline for each section and render it.
Cutting - Cannot See Video
By Teac23 in forum EditingReplies: 1Last Post: 19th Feb 2013, 08:10 -
Cutting out portions of video
By Jacks_Daddy07 in forum EditingReplies: 4Last Post: 18th Aug 2011, 17:18 -
Need help cutting out video segments and making one video with them
By darkcyber in forum DVD RippingReplies: 2Last Post: 23rd May 2011, 18:26 -
video cutting
By Mr anderson in forum EditingReplies: 2Last Post: 21st Oct 2010, 15:42 -
the right format for video cutting
By Aivc in forum EditingReplies: 7Last Post: 10th Apr 2010, 10:57
