Hi there,
at first, i dunno if this is the right forum to get help, if not, please Mods move my thread to the right forum.
I'm trying to encode some vob files with StaxRip 1.1.9.0 (got some reason to use older version, but i think that doesn't matter to my problem, since i tried with newer version and got same error).
I'm indexing the vob files via the feature 'merge files' here is the log file of staxrip:
And this is the created .avs file:Code:------------------------------------------------------------ Environment ------------------------------------------------------------ StaxRip version: 1.1.9.0 OS Name : Windows 7 Enterprise OS Version : 6.1.7601.65536 OS Type : 64-bit OS Culture : German (Germany) ------------------------------------------------------------ .NET ------------------------------------------------------------ v2.0.50727 : 2.0.50727.5420 v2.0.50727\1031 : 2.0.50727.5420 v3.0 : 3.0.30729.5420 v3.5 : 3.5.30729.5420 v3.5\1031 : 3.5.30729.5420 v4\Client : 4.5.50938 v4\Client\1031 : 4.0.30319 v4\Full : 4.5.50938 v4\Full\1031 : 4.0.30319 v4.0\Client : 4.0.0.0 ------------------------------------------------------------ Source file MediaInfo ------------------------------------------------------------ H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_1.VOB H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_2.VOB H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_3.VOB H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_4.VOB H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_5.VOB H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_6.VOB General Complete name : H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_1.VOB Format : MPEG-PS File size : 1 024 MiB Duration : 18mn 57s Overall bit rate mode : Variable Overall bit rate : 7 550 Kbps Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Default Format settings, GOP : M=3, N=12 Duration : 18mn 57s Bit rate mode : Variable Bit rate : 7 208 Kbps Maximum bit rate : 9 500 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Bottom Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.695 Time code of first frame : 00:00:00:00 Time code source : Group of pictures header Stream size : 977 MiB (95%) Audio ID : 189 (0xBD)-128 (0x80) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Muxing mode : DVD-Video Duration : 18mn 57s Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 26.0 MiB (3%) Menu ------------------------------------------------------------ DGIndex - Demux audio and index MPEG-2 ------------------------------------------------------------ "P:\StaxRip_1.1.9.0\Applications\DGMPGDec\DGIndex.exe" -i "H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_1.VOB" "H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_2.VOB" "H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_3.VOB" "H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_4.VOB" "H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_5.VOB" "H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_6.VOB" -ia 2 -fo 0 -yr 1 -tn 1 -om 2 -drc 2 -dsd 0 -dsa 0 -o "H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_1 temp files\VTS_02_1" -hide -exit Demuxer: DGIndex - Demux audio and index MPEG-2 Start: 14:38:11 End: 14:39:21 Duration: 00:01:10 ------------------------------------------------------------ Error opening source ------------------------------------------------------------ Evaluate: System exception - Access Violation (H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_1 temp files\VTS_02_1_Source.avs, line 2) MPEG2Source("%source_file%") Crop(0,0, -Width % 8,-Height % 8) ConvertToYV12() ------------------------------------------------------------ Index with ffmsindex ------------------------------------------------------------ H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_1 temp files\VTS_02_1.d2v "P:\StaxRip_1.1.9.0\Applications\AviSynth plugins\ffms2\ffmsindex.exe" "H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_1 temp files\VTS_02_1.d2v" "H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_1 temp files\VTS_02_1.ffindex" Failed to initialize indexing: Can't open 'H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_1 temp files\VTS_02_1.d2v' Start: 14:41:10 End: 14:41:10 Duration: 00:00:00
This is the error StaxRip is throwing at me:Code:LoadPlugin("P:\StaxRip_1.1.9.0\Applications\DGMPGDec\DGDecode.dll") LoadCPlugin("P:\StaxRip_1.1.9.0\Applications\AviSynth plugins\Yadif\yadif.dll") MPEG2Source("H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_1 temp files\VTS_02_1.d2v") Crop(0,0, -Width % 8,-Height % 8) ConvertToYV12() Yadif() Crop(0,0,-0,-0)
The whole setup was working well for me, for about 2 years. Now i recently needed some space on my c:\ drive and deleted and uninstalled some applications, seems like i removed one, which is needed by staxrip to work properly.Code:FFVideoSource: Can't open 'H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_1 temp files\VTS_02_1.d2v' (H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_1 temp files\VTS_02_1_Source.avs, line 2)
Things i've tried:
* Uninstalling and Reinstalling Avisynth
* Copying dlls to the avisynth plugin directory
* Uninstalling and Reinstalling Haali Media Splitter
I'm finished off with my latin and asking you what programs or dlls do i need to get StaxRip running again? I'm happy for every idea you got
Thanks in advance, let me know if you need any additional information from me to get things right again.
P.S.: Already tried to load the .avs in MeGUI, but it also resulted in an error, so i think it's not a generally staxrip problem, but has something to do with a missing program/plugin/whatever.
If vob files are consecutively numbered as per your log file:
VTS_02_1.VOB
VTS_02_2.VOB
VTS_02_3.VOB
VTS_02_4.VOB
VTS_02_5.VOB
VTS_02_6.VOB
and you open the first one with DGIndex, it can automatically include the rest when indexing and treat them as a single file. Most encoder GUIs do so by default. MeGUI has an option to disable/enable that under External Program Configuration. I don't know about StaxRip as I don't use it.
That makes no sense at all as the VTS_02_1.d2v file is the index file created by DGIndex and FFVideoSource is attempting to open it. I think by opening the set of vob files with the "merge files" function you're confusing StaxRip. Try opening just the first one and hopefully StaxRip will index them as a single file with DGIndex. For the record, MeGUI would do the same by default.FFVideoSource: Can't open 'H:\dvd\ABSCHIED\VIDEO_TS\VTS_02_1 temp files\VTS_02_1.d2v'Last edited by hello_hello; 28th Mar 2015 at 12:26.
I tried to select a single file, but it doesn't select the other ones.
I've always done it the way with merge files and selected all the consecutively numbered files.
I think StaxRip just uses FFVideoSource since the other encoder failed.
Strange behaviour of selecting only one file is, that it seems to be working, but it has just the runtime of one vobfile.
[edit]
It also seems working, when merging 2 files, but not with all of the files
[/edit]
[edit2]
I can't explain it myself, but StaxRip and MeGUI still working on other Vobsets, so i think my rip of the vobs is bad or smth similar. I'll try to rerip the files and report in afterwards
[/edit2]Last edited by drundl; 28th Mar 2015 at 13:08.
I've changed this log message now solving macros so next time such a problem arises it's clearer what happened, DGMPGDec can't handle this VOB set for unknown reasons, best thing to do is trying to rip the DVD with MakeMKV.Code:
Another solution would probably be to rip this DVD in "Movie/IFO mode" to either a contiguous "PGC VOB" file, or with "stream processing" = so that the main movie PGC gets already demultiplexed to the raw video (*.m2v) and audio stream(s); FFMS2 and L-SMASH Source are not able to handle VOB sets but should handle single input files correctly. This may require an NTFS partition, file sizes may exceed 4 GB; but this should be the default in this era.
By the way: DVDs ripped in "File mode" are often the reason why you get blatantly asynchronous audio streams: VOB files may contain several "program chains", e.g. publisher trailers in front of the main movie, which have different audio stream configurations. Some indexers may not recognize these delays correctly, especially when they don't care about IFO files. Extracting the main movie PGC only will skip such nuisances and should return an in-sync result (except for brief delays in case the audio stream was not perfectly cut during the encoding or authoring process).
AviSynth:can't get ffvideosource to work.
By sambat in forum EditingReplies: 5Last Post: 11th Nov 2015, 09:15 -
avisynth: how to apply colormatrix to vid=FFVideoSource?
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 25th Mar 2015, 11:04 -
MP4 video [FFVideoSource: Can't open] staxrip error
By mcy111 in forum Newbie / General discussionsReplies: 6Last Post: 11th Jun 2014, 07:29 -
How do I use AudioDub and FFVideoSource?
By Baniita in forum Newbie / General discussionsReplies: 8Last Post: 22nd Oct 2013, 03:53 -
DirectShowSource and FFVideoSource Problems
By ndjamena in forum Video ConversionReplies: 15Last Post: 9th Mar 2013, 00:04
