I'm looking for a good capture card to cap in that kind of resolution. If the card can do MPEG capture as well(hardware based) then that is fine but for the most part I will be capping uncompressed AVI and converting them using TMPEG. I am going to be using V-dub since I hear it supports some good features for captures. Any suggestions, thanks.
Results 1 to 10 of 10
I'm looking for something under the range of $200 if that's not too much to ask for.
Hi:
Get a WinTV Go with S-Video in for about $50.00.
And get these drivers.
http://btwincap.sourceforge.net
Capture with the Huffy CODEC and you'll be set.
kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net -
I use the Visiontek Xtasy Everything. It comes with WinDVD and WinDVR. The latter does realtime software mpg compression. I've used WinDVR to make vcds and it looks ok but for the best quality I use V-Dub and Tmpgenc. The card's ok for gaming as long as you don't need GeForce 3 or 4 performance.
I capture with a plain jane 32MB ATI AIW at (among other resolutions) 720x480, in either MPEG-2 or uncompressed AVI and it works just fine.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
I recently intalled a Pinnacle Studio Deluxe card with the Studio 7 software. Capture quality is much better than my old MJPEG card and video quality has been very good. No problems with lip-syn, my 45 minute analog capture came out surprising very well. I using a Althon 1800XP system with Windows 2000 and lots of Hard Drive space. Micro Center Computers has the complete package on sale for $250.00. I also use MediaStudio Version 6.5 for final editing and everything seems to work great. Highly recommended.
Wayne -
you don't need a new capture card to capture 720x480 just get the program called PowerVCR II it was modes that high. it works with my old Pctv Pinnacle Systems USB card which before I use this program it did not work at anything higher than 320x288 in Avi programs . But one thing is that this program does not use real res modes but if the card has them either way it does not matter because they program works and can capture even in SVCD (480x480) mode with any capture card and enables it in the reg which you can find in my other posts
8)
Robert -
Thanks kwag
for the website with wintv drivers. I was able to install the new driver for my hauppage win tv fm card,which i bought for 20 dolars (on sale), and now im able to capture at 720x480. Before i was only able to capture at 320x240 max which was driving me crazy and i was about to give up and either buy a new more expensive capture card or buy a new camcorder with firewire output but im glad i didnt. Once again thanks alot for saving me money and time.
Umm...this driver just made my card (WinTV Theater) worth keeping in Windows XPOriginally Posted by kwag
thx for the link kwag -
Take a look at the link in my signature for some captures I have made with the WinTV GO via S-Video. Specially the "Mixed" capture.
I'm glad the drivers worked for all you guys!.
http://www.kvcd.net
Cap Card Editing Issue?
By Evas1on in forum Capturing and VCRReplies: 7Last Post: 7th Jan 2010, 12:25 -
Suggestions On Buying Cap Card
By x420x Lovin in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 03:14 -
Capture Card Suggestions?
By duderdude2 in forum Capturing and VCRReplies: 0Last Post: 25th Sep 2008, 01:42 -
Dual Video Card Suggestions
By wwaag in forum ComputerReplies: 2Last Post: 29th Apr 2008, 15:09 -
Why DVD (720x480) bigger than AVI(720x480)
By psxiso in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 06:50
