Results 1 to 9 of 9
  1. how to convert subtitles xml format time "CC Closed captioning webplayer" to srt time 00h:00m:00s.000th
    EXAMPLE:
    2939 second
    "Durante más de 100 millones de años," carnívoros como este
    2943 second
    dominaron todos los continentes de la Tierra.
    2946 second
    Eran los depredadores supremos.
    2949 second
    El mundo no había visto
    "nada parecido antes,"
    2952 second 49.2 Minutes
    ni desde entonces.
    I could extract them, but I can not make them compatible.
    Thanks bro
    I think subtitle edit has a convert/import function that you can try. But I'm not sure if you will be able to get the time correctly.
  3. Originally Posted by roma_turok View Post
    Can you upload example xml file?
    http://www.mediafire.com/view/4b5t2honwud8qx8/transcripcion.xml
  4. Originally Posted by Baldrick View Post
    has worked with youtube, but not others sites. them used other methods in xml.
  5. Originally Posted by roma_turok View Post
    Don't know how to convert it
    but you can convert manually
    by converting seconds to minutes and seconds with http://www.calculatorsoup.com/calculators/time/decimal-to-time-calculator.php
    hahahaha
  6. WITH MICROSOFT EXCEL aplicate MM:SS to the second cell and paste the formule fx /86400 with selected cells
