Results 1 to 23 of 23
  1. Hi cats,
    please consider this source:
    https://dl.dropboxusercontent.com/u/39871584/test.avi
    I try to encode it to MP4 using ffmpeg:
    ffmpeg.exe -y -i test.avi -c:v libx264 -profile:v high422 -level:v 4.1 -g 33 -bf 2 -b:v 7900k -an -aspect 16:9 out.mp4
    but I see that out.mp4 don't playback fine in vlc, betweenn the graphic and video there is a kind of "jump" of the image
    https://dl.dropboxusercontent.com/u/39871584/out.mp4
    How can I resolve? thanks
    Try set the framerate with -r 25 ?
    Replace 25 with the actual framerate.
  3. Originally Posted by Baldrick View Post
    sorry but it don't resolve
  4. https://dl.dropboxusercontent.com/u/39871584/out.mp4
    this mp4 in my vlc playback wrong
    the problem is present between the dissolve from graphic, and the video
  5. You need to encode TFF, not progressive . VLC playback yadif 2x or bob
    Or bob deinterlace and make it 1080p50
  6. You still don't understand the difference between interlaced and progressive video?
  7. Originally Posted by poisondeathray View Post
    ah
    BOB deinterlace = -vf yadif=1:0 ?
  8. however yes: in this case I need to get progressive output, but seems I cannot find "bob" filter in ffmpeg
  9. I have try
    ffmpeg.exe -y -i test.avi -c:v libx264 -profile:v high422 -level:v 4.1 -g 33 -bf 2 -vf yadif=1:0 -r 50 -b:v 7900k -an -aspect 16:9 out.mp4
    but I don't know if is correct, and however playback remains wrong
  10. Yes, yadif in mode one is a smart bob. Not as good as QTGMC() in most cases.
  11. Code:
    ffmpeg.exe -y -i test.avi -vf yadif=1:0 -r 50 -c:v libx264 -profile:v high422 -level:v 4.1 -g 33 -bf 2 -b:v 7900k -an -aspect 16:9 out.mp4
    I have insert the yadif but in vlc I still see playback is not fine
  12. I wonder if the ffmpeg docs are backward regarding the field order. In every other version of Yadif order=0 is BFF.
  13. I cannot resolve
    I have try:
    ffmpeg.exe -y -i test.avS -c:v libx264 -profile:v high422 -level:v 4.1 -g 33 -bf 2 -b:v 7900k -an -aspect 16:9 out.mp4
    where test.avS is:
    LoadCPlugin("v:\automazioneclip\core\yadif.dll")
    ffvideosource("v:\test.avi")
    AssumeBFF()
    Yadif(mode=1)
    assumefps(50)
    but this don't resolve the problem, in the output mp4 I cannot see the dissolve, is there a "jump" in replace of dissolve
  14. Your video is TFF. AssumeTFF() or Yadif(mode=1, order=1).
    <edit>
    I went back to post #11 and found that the yadif parameters were correct. Unlike every other version of Yadif order=0 is TFF in ffmpeg. The file it produced worked fine in several players I tried -- except VLC which jumps suddenly from the titles to somewhere in the middle of the clip. If I encode directly with the x264 cli encoder there are still some problems when the bitrate and complexity is too high. It looks to me like this is a problem with VLC.
  15. ahn, thanks
    only to do a proof I would try use
    -b:v 7900k -minrate 7900k -maxrate 7900k -bufsize ?
    How have to be calculate the bufsize considering a bitrate of 7900k?
  16. Code:
    ffmpeg.exe -y -i audiosfilata.wav -i sfilata.avi -c:v libx264 -profile:v high422 -level:v 4.1 -g 33 -bf 2 -vf yadif,colormatrix=bt709:bt601 -b:v 8000k -minrate 8000k -maxrate 8000k -bufsize 8000k -c:a libmp3lame -b:a 320k -aspect 16:9 output8000.mp4
    this seems work, but I don't know if the bufsize=8000k is correct
  17. bufsize depends on your playback device's limitations. Why are you setting min, max, and average bitrates all the same? Are you aiming for constant bitrate encoding? That's the worst possible encoding method.
  18. I know but I'm not able to calculate final size in VBR mode. However I have a uncompressed .avi file of 460 GB that have duration of 1hour and 15 minutes, HD 1920x1080 25fps 4:2:2. I would like encode it into mp4 so that it fit
    - in a 4,7GB dvd
    - in a 9Gb dvd
    For example, to create a MP4 of 4.37Gb how I have to set min max and average rate? thanks
  19. Same answer, use a bitrate calculator . Not necessarily one for DVD-video, but a generic one
    eg this one is similar to the one in megui
    https://www.videohelp.com/software/Bitrate-calculator
    If it's not intended for a device (it probably isn't if you're using 4:2:2) , you usually don't want to set min/max or buffer or VBV settings. The more restrictions, the lower the potential quality
    The only important one is average bitrate, because that is what is used in the equation
    Filesize = average bitrate * running time
  20. Originally Posted by marcorocchini View Post
    duration of 1hour and 15 minutes - in a 4,7GB dvd
    It's simple algebra:
    running time = 1 hour 15 minutes = 4500 seconds
    file size = 4.7 GB = 4,700,000,000 bytes = 37,600,000,000 bits
    bitrate = file size / running time:
    37,600,000,000 / 4500 = 8,355,556 bits/sec = 8356 kbits/sec
    Subtracting a few percent for the container overhead leaves about 8200 kbits/sec. Subtract 384 kbps for audio (typical for 5.1 AC3) leaves you with about 7800 kbps for the video.
  21. Let me guess the response:
    "cats" don't do algebra
    <insert cat gif>
  22. oh ______
  23. Banned
    Oct 2014
    Northern California
    Hahaha!
