custom is set to 0.
This only really seems to happen with Game of Thrones but for some reason two of the episodes in season 4 refuse to rip to 1920x1080. Is there any way to force this in Handbrake? I thought the way to handle this was to switch cropping to custom and set all of them to 0. Unfortunately, a re-rip still leads to a video with black bars on the side.
Yeah black bars on the sides - the output has a resolution of 1822*1080
I assume resizing is set back to 1920x1080 after cropping is disabled? Are you using "anamorphic none" (modulus 2)?
I dont ever see the resolution change when I switch between the options.
I have that setting set to strict -
It should if you use anamorphic "none". Set the modulus to 2 so it can use any resizing it likes.
Bluray video isn't anamorphic anyway, it's all square pixels, so give anamorphic "none" a try. I don't use Handbrake much myself so I don't know it's quirks. In theory for non-anamorphic video, anamorphic "strict" should give you the same result, but if it's not showing you the output dimensions that way try anamorphic "none" instead.....
The problem might be that auto-cropping causes the resizing to change, but disabling cropping doesn't cause it to automatically change back to the original dimensions. Just a guess. I don't really know. -
Looks like I didn't notice the fact that the cropping settings were not at 0 when I switched to Custom. I was able to re-encode the two episodes that were giving me issues with cropping.
Thanks for the help guys! -
How to add black bars in video using handbrakecli command
I tried to execute below command
HandBrakeCLI.exe -i "D:\source.mp4" -t 30 --angle 1 -c 1 -o "D:\desti.mp4" -f mp4 -w 1280 --loose-anamorphic --modulus 2 -e x264 -q 20 --start-at duration:0 --stop-at duration:65 --vfr -a 1 -E av_aac -6 dpl2 -R Auto -B 160 -D 0 --gain 0 --audio-fallback ac3 --encoder-preset=veryfast --encoder-level="4.0" --encoder-profile=main --verbose=1 --pixel-aspect=2:2
but black bar is not added it increase video's width and height can anyone suggest me what I am missing
consequences of not cropping black bars
By codemaster in forum Video ConversionReplies: 13Last Post: 17th Dec 2014, 21:00 -
Getting rid of black side bars in TCM movies
By b1lanc in forum Newbie / General discussionsReplies: 39Last Post: 25th Aug 2013, 23:25 -
Small black side bars when capturing
By encodingmonkey in forum Capturing and VCRReplies: 13Last Post: 26th Jul 2013, 22:56 -
Cropping black bars on a 2.35:1 aspect video
By spicediver10191 in forum Video ConversionReplies: 4Last Post: 19th Jun 2012, 16:24 -
Handbrake cropping too much
By ryangarfield in forum Blu-ray RippingReplies: 2Last Post: 14th Jun 2011, 16:42
