Hi there,
Does anyone know the reason of having no audio with your captures
after loading footage from camera into computer?
This is the case:
Filming interviews, using 2 wireless microphones
2 XLR Receivers connected to Sony NX70 videocamera
Headphones: split audio - mic1 on Left / mic2 on Right
Playback on camera: audio = recorded with video
Captures from camera into computer: = no audio!
Importing captures in PPro CS5: = Only video track No audio!
I'm puzzled what could be the reason, how to set up for recordings tomorrow?
thx for you help!!
First, if you're hearing the audio on playback in the camera it's there -- so no worries about that.
What mode are you shooting in and how are you capturing?
With XDCam you copy the whole card structure to your system and link PPro to that. Audio and Video are separate files that require the metadata from the card structure and the NLE to link together. -
With my NX5U units I seem to recall issues with LPCM audio when I imported into Premiere Pro CS6. I would not get audio playback. After I switched audio to AC3 then the problems went away. I took a look at your camera's specs and I only saw LPCM as the recording/playback option.
I would try what smrpix suggested first. I can't recall if I copied the entire card structure when I had the audio issues so maybe that will be all you need to do. Also, in Premiere, import the video via Media Browser so that spanned clips import properly. I don't know if CS5 handles spanned clips though because I did not have NX5Us when I used it.
BrainiacLast edited by Brainiac; 27th Mar 2015 at 11:16.
thx for yr reaction and welcomming me.....
btw this is the first time this problem occurs.
my collegue loaded the footage into his computer and found the audio is connected.
this is the media info of my captures:
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=12
Codec ID : 27
Duration : 1mn 0s
Bit rate mode : Variable
Bit rate : 25.4 Mbps
Maximum bit rate : 26.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.245
Stream size : 183 MiB (91%)
Audio
Menu ID : 1 (0x1)
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Muxing mode : Blu-ray
Codec ID : 128
Duration : 1mn 0s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 11.1 MiB (5%)
maybe of any help
For comparison I post MediaInfo from captures with same camera
on an earlier job, for which we used 'VGA' (maybe different settings?)
Sorry I have poor knowledge on this matter. I submit yr answers to my collegue, who will be editing the interviews we shot.
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.0
Codec ID : 27
Duration : 11mn 48s
Bit rate : 21.5 Mbps
Maximum bit rate : 22.0 Mbps
Frame rate : 25.000 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.415
Stream size : 1.77 GiB (90%)
Audio
Menu ID : 1 (0x1)
Format : PCM
Codec ID : 128
Duration : 11mn 48s
Bit depth : 16 bits
Stream size : 130 MiB (6%)
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Duration : 11mn 47s
thx again.
bye
fixing audio sync without changing the video/audio quality of mp4 video
By aruwin in forum AudioReplies: 3Last Post: 8th Aug 2014, 00:10 -
Demux audio from ntsc video and mux with pal,audio sync problems
By luis67 in forum AudioReplies: 6Last Post: 17th Nov 2012, 05:43 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 12:25 -
How do you insert an audio clip between audio clips in AVS Video Editor
By johnharlin in forum EditingReplies: 1Last Post: 19th Apr 2011, 02:17
