  1. Please help a confused newbie. I am trying to convert some interlaced VHS material to 352x480 interlaced NTSC XSVCD. So both my source and my output are interlaced. To save some bandwidth I would like to crop some black overscan and then center the image. In the process of vertical cropping I am loosing some scan lines, so to make the compliant interlaced MPEG2 I need to add the cropped lines at some stage to make their number 480. At what step should these lines be added? If I crop in TMPGEnc add then set the output frame size to 352x480 I am loosing the bandwidth again. Or should I set the output size to e.g. 340x470 and TV will add the missing lines?
  2. You'd better do it in TMPGEnc, you won't lose bw as your adding black lines that compress really well, as opposed to the headnoise your cropping out which compresses badly.
