Hi all,
I'm converting flv files captured from rtmp streams to mp4 using ffmpeg.
Here are the command line parameters i'm using:
ffmpeg -i "%%a" -c:v libx264 -preset superfast -c:a libvo_aacenc -b:a 128k "mp4s\%%~na.mp4"
This works great when the captured files are encoded with AVC/Speex, but unfortunately some of them are encoded with Sorenson Spark/Nellymoser. The conversion still works, sort of. But it takes forever and the resulting mp4 files are huge (4 or 5 times the size of the flv file) and jerky in playback.
Any help for fine-tuning the ffmpeg parameters to work better with the Sorenson encoded files would be much appreciated.
Thanks for your time!
Can you post the full details of one those flv? Use mediainfo(view->text) or mediainfoxp.
And set crf value to lower the file size/quality. Like -crf 25 (increase for smaller size). -
Sure thing. Here are the details:
General
Complete name : G:\convert\convertToMP4\unconvertable\stream.flv
Format : Flash Video
File size : 28.1 MiB
Duration : 9mn 33s
Overall bit rate : 411 Kbps
Video
Format : Sorenson Spark
Codec ID : 2
Duration : 9mn 33s
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Bit depth : 8 bits
Audio
Format : Nellymoser
Codec ID : 6
Duration : 9mn 33s
Channel(s) : 1 channel
Sampling rate : 11.025 KHz
Bit depth : 16 bits -
It's probably the variable framerate that causes problem. You could try set a framerate with -r 30... But you will get sybc issues.
That made a huge difference, thank you! And the sync issues don't seem too bad (so far at least).
as a side note: one could extract the time codes using flvextract and add them later to the mp4 using mp4fpsmod. (this is the way I do it in Hybrid)
ffmpeg: Concatenating MP4 files adding chapters for each one
By Keyser in forum Video ConversionReplies: 6Last Post: 12th May 2022, 17:19 -
How to mux .264 and .wav files to .m2ts or .mp4 using FFmpeg????
By rallymax in forum EditingReplies: 1Last Post: 31st Oct 2011, 17:04 -
Converting everything to mp4 using ffmpeg
By euphonic in forum Video ConversionReplies: 1Last Post: 13th May 2011, 07:53 -
Can someone make me a ffmpeg file for normalizing mp4 files? I am Clueless.
By xrayengineer in forum DVD RippingReplies: 2Last Post: 3rd Feb 2011, 19:46 -
.enc or ffmpeg/Handbrakes switches -> .mp4 files playable by PS3 and Xbox 360?
By cwerdna in forum Video ConversionReplies: 3Last Post: 5th Jan 2011, 02:45
