Installed all updates, but still doesn't work.
I'll be trying new stuff tomorrow. This has got to be the most persistent error I've ever seen in my entire life.
While I'm gone, would you guys please be so kind to continue posting solutions? I'll read them tomorrow.
Results 31 to 60 of 74
Already tried. Nothing so far helped. And it was 0.95 that worked.
Any other ideas? Now I can't even install .net 4.0 again, it says that it failed.
What specific error message?
If you mean .net 4.0:
OS Version = 6.1.7601, Platform 2, Service Pack 1
OS Description = Windows 7 - x64 Home Premium Edition Service Pack 1
CommandLine = D:\55c3fe4eef542552325e5b1af155\\Setup.exe /x86 /x64
TimeZone = West-Europa (standaardtijd)
Initial LCID = 1043
Using Simultaneous Download and Install mechanism
Operation: Installing
Package Name = Microsoft .NET Framework 4 Client Profile Setup
Package Version = 4.0.30319
User Experience Data Collection Policy: AlwaysUploaded
Number of applicable items: 9
Exe (D:\55c3fe4eef542552325e5b1af155\SetupUtility.exe) succeeded.
Exe Log File: dd_SetupUtility.txt
ServiceControl operation succeeded!
Exe (D:\55c3fe4eef542552325e5b1af155\Windows6.1-KB958488-v6001-x64.msu) failed with 0x240006 - (null).
Exe Log File: CBS.log
MSI (D:\55c3fe4eef542552325e5b1af155\netfx_Core_x64.ms i) Installation failed. Msi Log: Microsoft .NET Framework 4 Client Profile Setup_20150327_164251231-MSI_netfx_Core_x64.msi.txt
Final Result: Installation failed with error code: (0x80070643), "Onherstelbare fout bij installatie. " (Elapsed time: 0 00:01:01).
"Onherstelbare fout bij installatie" means Unrecoverable error during installation in dutch. -
Try this
1) go to directory C:\Windows\Microsoft.NET , find and rename folder assembly
2) download and install Microsoft .NET Framework 4 Standalone Installer : http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=17718 -
I have run out of ideas
Let's just assume my PC is cursed.
Let's sum this up: Before I started this thread, Handbrake did not work. Now .net doesn't work, either
Seems to be a be a system configuration problem. Is msconfig set up for Normal Startup or Selective Startup?
OK then we may be getting somewhere here. List and record/save all the functions in Selective Startup that are TURNED OFF.
In your case lets look at both Services and Startup. It might be a (more than likely) Services.
Turned off (Services):
Windows Event Log
Windows Event Collector
Turned off (Startup):
Adobe Creative Cloud
Adobe Updater Startup Utility
Adobe CS6 Service Manager
Akamai Netsession Client
Apple Push
DAEMON Tools Pro
DAEMON Tools Lite
Google Update
AOL Service Libraries
KPeerNexonEU
LogMeIn Hamachi UI
Windows Live Messenger
Quicktime
SandboxieControl
Catalyst Control Center
Java Platform SE Auto Updater
SBSV 2010/02/19-11:02:07
Switcher
Toshiba Volume Regulator
Wondershare Studio
Dropbox -
So ASP .NET State Service is on right?
The last thing I would try is to startup in Normal mode instead of Selective mode and see what happens. Keep that list handy
so you can go back in case this doesn't work then you can get back to your original config. If this fails then the only thing I can
think of at the moment is Baldricks suggestion. A clean reinstall may be in order.Last edited by Dougster; 27th Mar 2015 at 14:00.
Any other software installed since then other than Windows updates? So basically, what changed?
Nothing. I didn't install a thing this week. I'm not near my pc now, but suggestions are welcome as always.
Out of curiosity, what are the two optional updates you said are available?
Weird artifacts when converting from MKV to MP4 in Handbrake/Mediacoder
By fighuass in forum Video ConversionReplies: 4Last Post: 1st Apr 2015, 01:01 -
AVANTI - NEW version - error of OLD version - need help
By ZviT in forum Video ConversionReplies: 2Last Post: 25th Mar 2015, 05:28 -
Install quick sync version of handbrake
By Placebo in forum LinuxReplies: 0Last Post: 4th Apr 2014, 02:59 -
Weird Problem with Handbrake
By LegendaryLero in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2011, 01:20 -
Handbrake working with new version of x264
By levick in forum Video ConversionReplies: 7Last Post: 18th May 2010, 21:25
