Hello, I'm using Windows 7 and Handbrake version 10.1.
Whenever I start it up, I get this message and when I try to encode, it gets stuck at 0.00%.
I already tried to contact Handbrake Support but I don't get answers.
An Unknown Error has occured.
System.NotImplementedException: De methode of bewerking is niet geïmplementeerd.
bij MS.Internal.AppModel.ITaskbarList.HrInit()
bij System.Windows.Window.ApplyTaskbarItemInfo()
bij System.Windows.Window.WindowFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
bij System.Windows.Interop.HwndSource.PublicHooksFilte rMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
bij MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
bij MS.Win32.HwndSubclass.DispatcherCallbackOperation( Object o)
bij System.Windows.Threading.ExceptionWrapper.Internal RealCall(Delegate callback, Object args, Int32 numArgs)
bij MS.Internal.Threading.ExceptionFilterHelper.TryCat chWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
Activity log:
http://pastebin.com/xH6NFZ3C
Results 1 to 30 of 74
If you google "MS.Internal.AppModel.ITaskbarList.HrInit()" you only get 8-16 results....Maybe something wrong with your windows installation or .net framework.
Tried reinstall .net 4.0? -
Will be trying that now.
EDIT: Do I need to reinstall 4.0 specifically? I have a newer version installed. -
Reinstalling .net 4.0 Client Profile didn't work. Any other ideas? I followed these instructions: https://trac.handbrake.fr/wiki/SupportFAQ#netFramework
Try follow this steps:
uninstall Handbrake
delete folder C:\Users\<username>\AppData\Roaming\HandBrake
uninstall any version Framework in Control Panel->Programs->Programs and Features
run .NET Framework Cleanup Tool with mode cleanup All Versions. link to download : http://blogs.msdn.com/cfs-file.ashx/__key/CommunityServer-Components-PostAttachments/0..._5F00_tool.zip
restart computer
install Framework 4 and Handbrake -
Still doesn't work. Thanks for the suggestions though, got any else?
Thanks, but it didn't work. Can I have some more, please?
It happens with vidcoder according to https://forum.videohelp.com/threads/370974-Softsubbed-MKV-to-Hardsubbed-MP4-in-TX264?p=...=1#post2381915
But it sounds like older versions work ? -
0.9.5 Works perfectly, 0.9.8 works but is stuck at 00.00% when encoding. All newer versions crash with this error.
Problem with system, not the software. Have you been keeping up with Windows Update? At least have the system setup for the
important ones ( I personally stay away from the optional ones unless there something that I particularly need ). -
Control Panel --> Windows Update --> Check to see if it is setup to receive at least Important Updates. This is something that
should setup when the machine was new (assuming it came with Windows 7) or if it was upgraded from an earlier
version of Windows (Vista maybe).
Also if the machine was built pre Windows 7 you might want to have the Bios updated to a newer version. Check with manufacturer of your machine or the motherboard manufacturer. -
I'm installing 5 important updates now, I'll tell you what results I get once I'm done.
There may be more. Check again after this round of updates. If you haven't had update setup, this may take a while. They come
in waves.
Hmm, he's kinda stuck at installing .net Framework 4.5. Should I stop the update and manually download it myself or let it continue?
No. Let it continue. I said this may take a while if Windows Update was never setup.
EDIT: A disk cleanup on the C: drive may be in order if a lot of updates are done.Last edited by Dougster; 26th Mar 2015 at 10:48. Reason: Additional info
No, how do I do that? It said there were none.
EDIT: I'm installing some new ones. It refreshed. -
Control Panel --> Windows Update --> in the upper left click on 'Check for updates'
Best of luck. I've got to go to work now. I'll check back later. (It's 1:04 pm here, I'll be back by 4:00 pm)
Weird artifacts when converting from MKV to MP4 in Handbrake/Mediacoder
By fighuass in forum Video ConversionReplies: 4Last Post: 1st Apr 2015, 00:01 -
AVANTI - NEW version - error of OLD version - need help
By ZviT in forum Video ConversionReplies: 2Last Post: 25th Mar 2015, 04:28 -
Install quick sync version of handbrake
By Placebo in forum LinuxReplies: 0Last Post: 4th Apr 2014, 01:59 -
Weird Problem with Handbrake
By LegendaryLero in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2011, 00:20 -
Handbrake working with new version of x264
By levick in forum Video ConversionReplies: 7Last Post: 18th May 2010, 20:25
