Hello guys, this is my first post on the forum.
I upload subtitles once and a while on Subscene.com. I've got a problem with people uploading copies of my subtitles all the time. Often they vary 50 bytes or less in size and I can't find the difference between mine and theirs.
Is there a program I can use to check where the changes are between 2 files? As it is now I risk flagging a perfectly good improvement as a stolen subtitle.
I hope you guys can help me.
Unless you obtain an agreement with the copyright holder they are not your subtitles.
Subtitles, are protected derivative works according to copyright law.
So the irony: you complain that work you stole is stolen by others.
Personally I have no problems with people making subtitles but to claim they are yours and your efforts to protect them borders absurdity.
If you made the subs originally then you have a right to complain,contact Subscene.com and explain the situation and they should take down the copied subs as long as you can prove original ownership.
Assuming your subs are .srt, give ExamDiff a try. There's lots options of how you want to view the differences.
Device/software similar to Dazzle for Windows 8?
By JudgeGarth in forum Capturing and VCRReplies: 9Last Post: 19th Aug 2013, 18:44 -
VirtualDub similar software
By Matteo in forum Newbie / General discussionsReplies: 11Last Post: 7th Sep 2012, 07:11 -
Compare subtitles timings
By Bondurant in forum SubtitleReplies: 4Last Post: 6th Sep 2012, 17:23 -
Software Similar To ConverXDVD
By niteghost in forum Authoring (DVD)Replies: 3Last Post: 30th Jan 2012, 15:11 -
Video Compare simultaneously software ?
By deadea59 in forum Software PlayingReplies: 7Last Post: 15th Jan 2011, 06:43
