Hi cats,
from my NLE I have exported my interlace video in 4:2:2 YUY2 uncompressed 1920x1080: this is outputNLE.avi
I would like generate a MP4 that is playable in pc desktop with, for example, VLC
Consider that outputNLE.avi is BT.709 colormatrix, and as sayd, is interlaced
To achieve the MP4 I would try:
-->deinterlace it ( using avisynth: yadif() )
-->colormatrix from 709 to 601
-->encode MP4 as progressive 4:2:2 (using Mainconcept Totalcode or Elecard converter studio)
is correct my procedure? thanks
Why would you convert to rec.601? Just encode with the original rec.709 and flag it. Just about every player will play it with the correct colors if you do that. And if you must use rec.601 colors be sure to flag them. Most players will default to rec.709 if the video is HD.
4:2:2 chroma subsampling is a much bigger problem outside of a computer. Few devices can handle it.Last edited by jagabo; 25th Mar 2015 at 22:29.
Colormatrix Question
By tebugg in forum Authoring (DVD)Replies: 3Last Post: 9th Oct 2014, 19:42 -
Virtualdub rec.601 <--> rec.709 colormatrix conversion
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2014, 20:06 -
how to change colormatrix in MEncoder?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 2nd Nov 2013, 15:00 -
Virtualdub Rec.709-->Rec.601 colormatrix conversion
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 13th Oct 2013, 14:08 -
how to fix levels if they exceed rec.601
By codemaster in forum RestorationReplies: 5Last Post: 12th Sep 2013, 09:09
