  1. Hi
    please can anyone help a cat?
    vid=FFVideoSource("j:\sfilataESP\sfilata.avi")
    aud=FFAudioSource("j:\sfilataESP\audiosfilata.wav")
    yadif(1,1)
    audiodub(vid, aud)
    now I would like add to the video part:
    AssumeFPS(25)
    ConvertToYUY2(interlaced=true)
    ColorMatrix(mode="Rec.601->Rec.709")
    but I have to tell avisynth that this lines have to be added to the video part, because there are present vid=FFvideosource... and not the standard FFvideoSource...
    How can I do? thanks
    and then:
    my source is uncompressed .avi interlaced
    I need that output of avisynth after the Yadif(1,1) is progressive: for that is it correct that I use ConvertToYUY2(interlaced=true) ?
  2. aud=FFAudioSource("j:\sfilataESP\audiosfilata.wav" )
    yadif(1,1)
    AssumeFPS(25)
    ConvertToYUY2(interlaced=false)
    ColorMatrix(mode="Rec.601->Rec.709", clamp=0)
    vid=last
    audiodub(vid, aud)
  3. Member Skiller's Avatar
    Oct 2013
    Germany
    vid=AssumeFPS(vid, 25)
    vid=ConvertToYUY2(vid, interlaced=true)
    vid=ColorMatrix(vid, mode="Rec.601->Rec.709")
    poisondeathray's suggestion is easier because it simply uses (the invisible) "last" instead of "vid" which would have to be explicit for every line as seen here.
    It's not incorrect in the sense that it would produce garbage but you will squeeze out slightly more vertical chroma detail if you put ConvertToYUY2() somewhere after Yadif, without interlaced=true (false is the default).
  4. thanks ^^
