Results 1 to 9 of 9
  1. Hi guys i need your help and it's urgent
    I've been trying to encode a video with this command
    ffmpeg.exe -i Input.mp4 -strict -experimental -acodec aac -ab 40k -vcodec mpeg4 -s 320x240 -b:v 400k -minrate 0k -maxrate 600k -bufsize 4096k -r 23.976 output.3gp
    But i want the audio to be between 40k and 64k but the video output is like this
    Video
    Format                                   : MPEG-4 Visual
    Format profile                           : Simple@L1
    Format settings, BVOP                    : No
    Format settings, QPel                    : No
    Format settings, GMC                     : No warppoints
    Format settings, Matrix                  : Default (H.263)
    Codec ID                                 : 20
    Duration                                 : 1h 2mn
    Bit rate mode                            : Variable
    Bit rate                                 : 400 Kbps
    Maximum bit rate                         : 600 Kbps
    Width                                    : 320 pixels
    Height                                   : 240 pixels
    Original display aspect ratio            : 16:9
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 fps
    Bits/(Pixel*Frame)                       : 0.217
    Stream size                              : 177 MiB (90%)
    Writing library                          : Lavc55.58.102
    Language                                 : English
    Audio
    Format                                   : AAC
    Format/Info                              : Advanced Audio Codec
    Format profile                           : LC
    Codec ID                                 : 40
    Duration                                 : 1h 2mn
    Duration_LastFrame                       : -9ms
    Bit rate                                 : 40.0 Kbps
    Channel count                            : 2 channels
    Channel positions                        : Front: L R
    Sampling rate                            : 48.0 KHz
    Stream size                              : 17.7 MiB (9%)
    How can i change the output audio bitrate?
    If i try to encode both separately and mux it, it's showing constant bitrate for the video and audio.
    Thanks in advance
    WHy do you need it to be vbr 40k-64k? Problem with standalone player?
  3. Actually i am ok even if its constant audio but how can i have a different bitrate than the video?
    If i use -b:v 400k -minrate 0k -maxrate 600k it is also used in the audio,i just want it to be in the video file
  4. Bump
  5. try to group video bitrate and audio bitrate, if not then probably you need split signal chain trough -map and do this as separate instances https://trac.ffmpeg.org/wiki/How%20to%20use%20-map%20option
  6. Sorry but i don't understand can you please tell me how to use it in my case?
  7. -minrate:v 0k -maxrate:v 600k
  8. Originally Posted by poisondeathray View Post
    Thankyou
