I have four Samsung TVs in my house all hooked up to my LAN via ethernet cable. I also have a Synology NAS that streams MP4 videos to those TVs. The MP4s were encoded with Handbrake (using the High Profile preset). For some reason there is one MP4 file that I cannot play on my oldest TV. It is a 2009 Samsung LN46B650 and it connects to the NAS via DLNA (unlike the three newer TVs purchased between 2011 and 2014 which connect to the NAS directly using the NAS's media server).
This one TV can play all other MP4s created by Handbrake except this one. When I try to play around with the Handbrake settings and choose MPEG4 instead of H264 (and use two-pass) the old TV will play the file but the audio is slightly out of sync. Any suggestions on how I can figure out why I can't play this one single file??
Results 1 to 26 of 26
What exactly does "cannot play" mean? What are the symptoms?
Post the full details from the mp4. Use MediaInfo. View -> text.
Or try use the normal profile in HandBrake. -
I've tried Normal as well.
I've even tried using the MP4 file produced by Handbrake (High Profile) as an input to create another High Profile (and Normal Profile) MP4 and the resulting files still cannot be played.
I've even used AGK to create an AVI file from the original source, and then used that AVI as an input to HB. The MP4 file produced by HB still cannot be played.
I've tried moving the MP4 file to another storage location on my NAS (to rule out the NAS as the source of the problem) and that made no difference.
Normally I can figure these kinds of issues out, but this one has me scratching my head.
I will post the MediaInfo stuff later today. -
Handbrake automatically crops black bars from videos. By default it may leave the width or height a mod 2 size (an integer multiple of 2) depending on the size of the black bars. Many devices require mod 4. Some even require mod 8 or 16. So some players will reject a frame size like 1918x1080 (1918 is mod 2) but have no problem with 1916x1080 (1916 is mod 4).
Would be a good idea to also post a "compliant" file 's spec for comparison.
Scott -
Here is the media info:
General
Complete name : G:\bh.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 1 018 MiB
Duration : 1h 41mn
Overall bit rate : 1 397 Kbps
Writing application : HandBrake 0.10.1 2015030800
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Duration : 1h 41mn
Bit rate : 845 Kbps
Width : 720 pixels
Height : 360 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Variable
Frame rate : 23.976 fps
Minimum frame rate : 19.978 fps
Maximum frame rate : 642.857 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.136
Stream size : 615 MiB (60%)
Writing library : x264 core 142 r2479 dd79a61
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Color range : Limited
Audio #1
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 41mn
Bit rate mode : Variable
Bit rate : 160 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 117 MiB (11%)
Title : Stereo / Stereo
Language : English
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : ac-3
Duration : 1h 41mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Bit depth : 16 bits
Stream size : 280 MiB (27%)
Title : Surround / Surround
Language : English
Menu
Codec ID : text
Duration : 1h 41mn
Language : English
00:00:00.000 : Chapter 1
00:07:14.884 : Chapter 2
00:14:37.126 : Chapter 3
00:21:48.390 : Chapter 4
00:24:32.087 : Chapter 5
00:29:34.022 : Chapter 6
00:36:57.298 : Chapter 7
00:44:17.688 : Chapter 8
00:50:48.303 : Chapter 9
00:54:32.228 : Chapter 10
01:00:43.398 : Chapter 11
01:07:11.820 : Chapter 12
01:11:53.902 : Chapter 13
01:16:25.873 : Chapter 14
01:24:43.370 : Chapter 15
01:31:51.882 : Chapter 16
Bit rate mode : VBR -
Variable frame rate is the issue.
Then why does this file play just fine:
General
Complete name : G:\dd.mp4
Format : MPEG-4
Codec ID : mp42
File size : 447 MiB
Duration : 21mn 16s
Overall bit rate : 2 936 Kbps
Video
Format : AVC
Codec ID : avc1
Duration : 21mn 16s
Bit rate : 2 576 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Original display aspect ratio : 16:9
Maximum frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.311
Stream size : 392 MiB (88%)
Audio #1
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 21mn 15s
Bit rate : 160 Kbps
Stream size : 24.3 MiB (5%)
Language : English
Audio #2
Format : AC-3
Codec ID : ac-3
Duration : 21mn 15s
Bit rate : 192 Kbps
Bit depth : 16 bits
Stream size : 29.2 MiB (7%)
Language : English
Menu
Codec ID : text
Duration : 21mn 15s
Language : English
Bit rate mode : CBR
00:02:48.018 : Chapter 2
00:09:07.897 : Chapter 3
00:15:43.893 : Chapter 4 -
Look at the difference in the frame rates of the affected file.
I did notice one odd value in my problem file:
Is this not right? My other TVs play this file just fine. Just not the 2009 model. -
Re-encode it as a constant frame rate.
Maybe you can just patch the header to indicate the max frame rate is a more reasonable value.
I don't know, I'm just speculating. But MediaInfo doesn't parse the video stream, it only reads the header information. So that information must be in the header.
<edit>
You might try remuxing the file with mp4muxer or yamb.Last edited by jagabo; 25th Mar 2015 at 10:28.
I tried this but the resulting file still cannot be played. Well, I "think" I tried it. The only thing I did to override the HB preset was to select constant frame rate. I didn't actually specify a frame rate because I assumed it would do so automatically. There are so many to choose from I don't know which to pick.
I can't find the post that discusses this now but as I understand it Handbrake usually uses variable frame rates for NTSC material in MP4 because MP4 uses a fixed time base (something like 1/80000 sec) that can't give exactly 30000/1001 or 24000/1001 fps. So it flags videos with those frame rates as VFR and alternates the display times for individual frames so they average out to the correct value. If you encode to MKV instead you won't have this problem.
Yep. Get a portable player or a htpc that plays everything.
Did you do what Jagabo recommended?
Demux to elemental streams, Then Remux the streams into an mp4 with mp4box/yamb. Enter 23.976 fps. in the framerate box.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Need to batch (or queue) convert raw h264 file to mp4
By dukestravels07 in forum Newbie / General discussionsReplies: 10Last Post: 29th Mar 2015, 11:45 -
Damaged MP4 (h264) File - Need expert help
By TubeBar in forum Video Streaming DownloadingReplies: 13Last Post: 7th Oct 2014, 06:31 -
several VOB files to single file (mp4)
By smondal29 in forum DVD RippingReplies: 1Last Post: 24th Jun 2011, 03:23 -
Help on an H264 MP4 file...
By mjaeson in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2010, 10:05 -
MP4/h264 Exact File Size Encoding
By Trismegistus in forum Video ConversionReplies: 1Last Post: 23rd May 2010, 08:57
