Hi,
and I'm a caT
please respect for cats
Please I wonder: can I set the "mpeg audio version 1" ? thanks
ffmpeg can't encode it , no "E"
ffmpeg -codecs
D.A.L. mp1 MP1 (MPEG audio layer 1) (decoders: mp1 mp1float )
DEA.L. mp2 MP2 (MPEG audio layer 2) (decoders: mp2 mp2float ) (encoders: mp2 mp2fixed libtwolame )
DEA.L. mp3 MP3 (MPEG audio layer 3) (decoders: mp3 mp3float ) (encoders: libmp3lame )
DEA isn't "drug enforcement agency"
Codecs:
D..... = Decoding supported
.E.... = Encoding supported
..V... = Video codec
..A... = Audio codec
..S... = Subtitle codec
...I.. = Intra frame-only codec
....L. = Lossy compression
.....S = Lossless compression
mp2enc is what you should be looking for;
http://linux.die.net/man/1/mp2enc
You can download the mjpegtools package for Windows, or try to build it from the source-code
As for the cats, well, ......Last edited by El Heggunte; 24th Mar 2015 at 02:52. Reason: better wording
can ffmpeg set to "verbose off"?
By marcorocchini in forum Newbie / General discussionsReplies: 9Last Post: 20th May 2014, 15:33 -
the "-intra" command in ffmpeg.exe affects encoding "-vcodec copy" mode?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2013, 15:53 -
AVI XVID; MPEG 1 Audio Decoder set to "First Channel" or muffled audio
By SeeBettor in forum Newbie / General discussionsReplies: 6Last Post: 20th Nov 2012, 10:46 -
How to edit "info.dvr" + How to match a particular MPEG format with FFMPEG
By falco2000 in forum Video ConversionReplies: 8Last Post: 27th Sep 2012, 11:00 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52
