Hi!
I currently have 2 mkv files (different sources of the same movie) that I want to append using mkvmerge.
However, everytime i try to append these 2 files, the video freezes at the point where they merge.
Things I've tried doing, but resulted in failure:
1. extracting the raw file using mkvextract and then appending them in mkvmerge.
2. encoding the first file to possibly match the settings of the 2nd file (resolution, bit rate, frame rate, etc) using handbrake, before i appended them.
has anyone tried doing this successfully?
Hoping someone can help!!
Thanks in advance!
You might be fighting a losing battle. I assume MKVMerge is offering warnings regarding the codec private data not matching, or something similar?
You might find it's easier in the long run to re-encode both files with the same encoder settings and append the encodes. There's an x264 encoder option --stitchable which should ensure the encodes can be appended, but I' don't use Handbrake so I don't know if the version of x264 it uses supports that option or how you'd add it to the command line.
There's probably a GUI or three that'll encode separate files as a single encode so you don't need to append them but I can't think of one of the top of my head (I'd do it with Avisynth, but that has a fair learning curve). Someone may be able to suggest something.
Having trouble joining various FLV files using mkvmerge
By ragz4ragz in forum EditingReplies: 4Last Post: 9th Nov 2013, 07:45 -
Append on mkvmerge error
By blinkmadden in forum EditingReplies: 3Last Post: 29th Mar 2013, 21:47 -
Joining video files in mkvmerge
By Zee530 in forum Newbie / General discussionsReplies: 0Last Post: 13th Oct 2011, 14:29 -
Problem joining 2 MKV into 1 with MKVMerge.
By LiBiDoXP in forum Video ConversionReplies: 4Last Post: 29th Dec 2010, 01:07 -
joining avi files with diff frame rate-error in vd
By leel in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2010, 18:49
