Hello, I have Sony Vegas Pro 13 x64, and I am trying to render a video.
When I render normally, with Sony AVC codec or MainConcept AVC, the output colors are just the same as input video.
But I want to x264wfv plugin to render the video into x264 (lossless or maybe CRF), I like x264wfv more, because I can focuse on quality than bitrate. Sony AVC and MainConcept AVC are actually headache in terms of outputing maximum quality with not huge size.
So, well, I rendered the video with x264vfw, here is the image of rendering settings:
and here is the ouput:
As you can see, the output video colors are almost identical, but only red colors are lighter than original video. I don't understand, what's wrong with x264wfv? Why it does not just make everything the same? why it changed red colors?
Well, I just want totaly same output in terms of color. Is there any other x264 encoder for Sony Vegas?
Most YUV codecs will limit the luminance and chrominance ranges to the limits based on TV broadcast standards (ITU-R BT.601/709). You may need to either be able to activate a "full range" encoding to avoid that (AVCHD cameras may call that "x.v.Colour"), or avoid rendering colors beyond these limits.
By the way, x264 is like a trademark. If you are looking for another encoder, it won't be x264 anymore. The standard is called H.264 or MPEG-4 AVC. But a different H.264 encoder won't solve your problem -
Hey guys, I have fixed this problem.
After soooooooo much Googling and testing and Googling and testing and testing, here is what I did finally:
At first, I'll say that this is the information of the source file:
Downloaded from: Youtube
Resolution: 3200x1800 (almost 4K)
Framerate: 30fps
Bit depth: 8 bits
Color space: YUV
Duration: 3 hours and 41 minutes
And, well, the Project Properties in Sony Vegas:
Pixel format: 32-bit floating point (video levels)
--> NOTE: the colors in Sony Vegas Preview window was absolutely the same as source colors. I mean, there was no problem about studio RGB vs Computer RGB.
And, this is what I did:
I just typed this text in the command line tool in x264wfv window:
--range pc --colormatrix bt709
That's it. It just rendered fine. Absolutely the same color output as source.
Sony Vegas Red JPGs on Timeline ?
By blewyn in forum EditingReplies: 4Last Post: 5th Feb 2012, 19:23 -
How may I access to Boris RED 5 in SONY VEGAS 11?
By daniel827 in forum Newbie / General discussionsReplies: 4Last Post: 8th Jan 2012, 22:39 -
how can I learn color correction in Sony Vegas
By codemaster in forum EditingReplies: 1Last Post: 3rd Jan 2012, 09:02 -
Improve color in Sony Vegas 8
By namphong0612 in forum EditingReplies: 2Last Post: 25th Sep 2011, 22:06 -
Output Size of PAL VCD Rendered In Sony Vegas Pro 10 Is Too Huge
By LeHuoXuan in forum Authoring (VCD/SVCD)Replies: 8Last Post: 28th Feb 2011, 21:40
