At least according to this very non-comprehensive test that I found:
http://forum.mediacoderhq.com/viewtopic.php?f=4&t=13184&start=10
According to the poster:
Quality from best to worst
x264 veryslow 2pass > x265 medium > NVENC H265 ≥ x264 medium > NVENC H264
The big thing is that speed was said to be 200fps!
He has posted some test samples, I just received my tax refund, I think I'm going to have to treat myself and run some extensive tests to see how accurate his assessments are.
The other thing to remember is that the new NVENC exposes a number of quality settings that Media Coder doesn't support at the moment, only the plugin for Premiere Pro has those options, so it may be that with better settings NVENC could move up in the ranks of quality, at the expense of speed.
				Results 1 to 11 of 11
	this would mean the exact opposite of what your title says.Quality from best to worst
 NVENC H265 is worse in quality than x264 and x265, it is only faster, also without exact settings and the source no one can reproduce the results.users currently on my ignore list: deadrats, Stears555, marcorocchini
	How does it mean "the exact opposite"? It says that NVENC H265 is greater than or equal to x264 medium, as for the source it's a well known test sequence that I have seen and used dozens of times and you know the exact presets used for the software encoders and as I pointed out Media Coder doesn't yet expose any settings for NVENC, so...
	it also sais that nVENC H265 is worse than x265 medium and x264 veryslow 2pass,...
 + I only see a single screen shot and I'm not surprised that with a relative low bit rate (when looking at the source and source resolution) an encoder with more smoothing will win. (Depending in the settings VP9 will also be better than x264 medium)users currently on my ignore list: deadrats, Stears555, marcorocchini
	So "x264 veryslow 2pass > x265 medium > NVENC H265" means that "x264 veryslow 2pass" is better than NVENC H265 and "NVENC H265 ≥ x264 medium" means that "NVENC H265" isn't clearly better and x264, otherwise a ">" would have been used. Summing that up, it seems wrong to state that 'Nvidia NVENC HEVC is better than x264'.  users currently on my ignore list: deadrats, Stears555, marcorocchini users currently on my ignore list: deadrats, Stears555, marcorocchini
	I have a question:
 What graphics cards work with Nvidia CUDA HEVC?
 How to set the parameters for the encoder? I would like to test it a little bit.
	for H.265 encoding you need a Marvell or newer NVIDIA card.
 If you use NVEncC you can set them through the command line.How to set the parameters for the encoder?users currently on my ignore list: deadrats, Stears555, marcorocchini
	Marvel (without the extra L is a comic book company), Maxwell is the gpu architecture named after a physicist (not the coffee).
 With Media Coder you can click on "encoder" and a new window will pop up that allows you to configure some parameters, though that implementation doesn't yet expose all the settings.
	LOL, nice typo from myself.  users currently on my ignore list: deadrats, Stears555, marcorocchini users currently on my ignore list: deadrats, Stears555, marcorocchini
  ffmpeg with '--enable-nvenc'By Selur in forum Video ConversionReplies: 1Last Post: 13th Jan 2015, 06:45
  Compatible H.264 for Premiere (lossless NVENC)By Dogway in forum EditingReplies: 1Last Post: 19th Sep 2014, 10:17
  theX.265 (a free HEVC) codec. Have you ever tried that HEVC encoder? (HELP)By Stears555 in forum Video ConversionReplies: 41Last Post: 16th Sep 2013, 11:15
  show x264 command line output when using megui as x264 guiBy codemaster in forum Video ConversionReplies: 4Last Post: 12th Mar 2013, 10:35
  Bitrate vs Size Calculator for x264 for ripping DVD to x264 + AC3By Bonie81 in forum DVD RippingReplies: 7Last Post: 5th Jul 2010, 18:24
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
 Quote Visit Homepage
				Visit Homepage
