I'm trying to use VAC to blend 2 mics connected to a PC into one audio mix, audible through 2 speakers, they currently come through one speaker each, my audio set up is as follows.
Windows 7 PC, 2 Singstar wireless mics with one wireless receiver, Realtek HD, audio out cable on PC to RCA in amp/speakers.
Windows only recognises 1 mic by default, so i have to go into Windows sound settings and change the mic receiver under the recording tab from 1 channel to 2 channel.
I tried the following which another user found successful, and this mixed the blue mic through both speakers, while the red stayed through one!
So under Channel Config select "Custom" and select only the "FC" check box.
4) Click the Start button and you should now hear yourself through your speakers.
Any VAC users out there that can advise me please?
Results 1 to 1 of 1
No audio on one SCART cable,another cable is fine?
By SkC1998 in forum Newbie / General discussionsReplies: 25Last Post: 15th Feb 2014, 11:58 -
Virtual video cable for Colossus ? {Please Help}
By luigi41 in forum Software PlayingReplies: 5Last Post: 15th Oct 2013, 09:38 -
Audio Delay Upon Hooking Up New HDMI Cable (using separate digital audio)
By sonicdeth in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2012, 13:28 -
n00b question about pc and hd cable
By NateDizzle in forum Capturing and VCRReplies: 10Last Post: 17th Mar 2011, 16:35 -
General Cable question
By acrumbacker in forum Newbie / General discussionsReplies: 5Last Post: 1st Jan 2011, 21:00
