i have a MPG file that has two audio tracks (track 1 is the song and track 2 is the music), i want to convert that MPG file to MKV format but with only two audio channels, left channel is from track 2 and right channel is from track 1. Any video converter software out there that allows me to combine that two audio tracks into one track that has two channels ? thx
I'm pretty sure you must use an audio editor if you want to join each audio track as left and right channels. Extract the audio with for example AoA Audio Extractor Basic . Import the audio in audacity and copy each track in a new audio file as left and right channels. Save as mp3,mpa/mp2, wav. Last add the mpg and new audio in mkvmergegui and make a mkv.
Or maybe it's possible directly with ffmpeg (command line utility) but I have no idea how that command would look like.Last edited by Baldrick; 22nd Mar 2015 at 03:39.
thanks
wow! that sounds complicated, any video converter software that can do the above merging with some clicks? thanks -
Can it merge two audio tracks to left and right channels in one step?
any video converter cannot do that, i have tried it, i am searching for other video converter software that can do that .
Nope. I have not seen any software with that feature.
Combine audio tracks in Audacity of different formats
By quadrplax in forum AudioReplies: 4Last Post: 28th Jun 2013, 01:28 -
Combine subtitle tracks in MKV
By Hikaru-Shindo in forum SubtitleReplies: 0Last Post: 16th May 2012, 04:42 -
[SOLVED] Application to combine video + sound tracks?
By yetanotherlogin in forum Newbie / General discussionsReplies: 15Last Post: 22nd Apr 2012, 18:38 -
Need to combine .mpg files to one (What to use)
By neworldman in forum EditingReplies: 5Last Post: 26th Jan 2011, 18:23 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56
