I've recorded VHS > DVD+R on a Panasonic DVD recorder, with a top menu. The DVD seems to play ok on my Mac in DVD Player.
However MPEGStreamclip reports an error when I try and import the first Vob.
VLC will also not play the first Vob and says it has 0 bytes.
MediaInfo reports info that I know is completely incorrect (eg states it's NTSC when it's PAL, reposrts screen dimensions as half what they actually are, etc). So I guess the header might be screwed? How do I fix the vob? The other 3 on the disc appear to be ok.
Is ProjectX not Windows only? I'm looking for Mac solution.
I've tried MPEGStreamclip again and ignored the import errors. I tried to re-save the vob as mpeg, but it throws an error and stops encoding at the exact point the second title within the vob occurs.
It was recorded in XP mode on the DVD recorder. The image is definately full PAL size when I watch it back in DVD Player.
I think the header for that file has been written wrongly by the DVD recorder. MediaInfo declares the vob is 0.36 seconds long!
Is there anything that can strip/re-write/ignore the header?Last edited by Gibson's Squares; 21st Mar 2015 at 19:12.
No, ProjectX is a Java based program and only needs to be compiled on a Mac.
Which might be a bit tricky if you haven't compiled java source code before,..
I had to do the following:- download and install Java SDK
- download ProjectX
- open a terminal and go to my Download folder and there into the ProjectX folder
cd ~/Downloads/Project-X_0.91.0 - make the build script executable
chmod +x build.sh - call the build script
./build.sh
-> this created a ProjectX.jar file which I can double click inside Finder and thus start ProjectX - copied all files ProjectX uses into a new folder named 'ProjectX', zipped and attached it here
How to fix broken CC?
By impmon2 in forum SubtitleReplies: 1Last Post: 31st Dec 2014, 11:59 -
is it possible to fix or repair some broken or corrupted mp4 files?
By nanyobis in forum Video ConversionReplies: 8Last Post: 17th Aug 2013, 12:36 -
how can i fix a broken video file?
By morningfrost in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2013, 12:50 -
Broken WMV file shows height of 0 -- how to fix?
By Calidore in forum Video ConversionReplies: 1Last Post: 10th Jun 2012, 11:16 -
how to fix broken avi seeking?
By muffinman123 in forum Newbie / General discussionsReplies: 1Last Post: 9th Dec 2011, 17:40
