When I add a TS file (which is MPEG2 720x576 25fps, ac3 48khz) & an srt to finish as a mkv, the following message comes up while in progress.
Warning: Found at least one B frame without second reference in a non closed GOP.
What does this mean? any issues with frame rate or audio sync? I'm clueless. Everything seems fine when playing, but I thought it might be worth asking.
This means that the video stream is broken in at least one place and there might be some glitches in the playback. (depends on how good/robust the decoder is in covering corruptions inside the video stream)
Since your input is mpeg2 video I would generally recommend to send your input through ProjectX ( and cut the raw streams with Cuttermaran if need be).
ProjectX will extract and tries to fix errors in your video and audio streams, which you can then use with mkvmerge to create your new file.users currently on my ignore list: deadrats, Stears555, marcorocchini
VidOn Box - A high cost performance Android Box
By Jency in forum DVD & Blu-ray PlayersReplies: 15Last Post: 21st Aug 2014, 01:01 -
Event Pan/Crop Dialogue Box Tab, revert to Dialogue Box?
By saiiyu in forum EditingReplies: 2Last Post: 10th Feb 2014, 16:26 -
Will my store-bought DTA box do the same thing as a Comcast DTA box?
By locust78 in forum DVB / IPTVReplies: 7Last Post: 25th Feb 2013, 19:26 -
BD Rebuilder Error Message MKVMERGE
By howcho in forum Authoring (Blu-ray)Replies: 3Last Post: 20th Sep 2011, 15:19 -
Question how to eliminate warning message when rt click open mp3
By jimdagys in forum AudioReplies: 4Last Post: 8th May 2010, 05:04
