Hi
I'm recoding in 1440p (1920 x 1440) with my GoPro so that I can "tilt" up and down during editing and output to 1080p. The highest framerate on my Gopro in this mode is 48fps. If I output to 24fps, slowmotion will be smooth and all is good. At least that's what I thought.
But the end result is not good. There is a stutter, dropped frames or something that makes the video look far more shaky than it actually is.
If i export to 30fps the video looks much better. This does not make any sense to me, it should be the other way around.
The MP4 files from the Gopro is converted to AVI with GoPro Studio, and then edited in Adobe Premiere Elements 13,1. Project settings in PRE is DSLR 1080p24 (23,976).
Why not go straight to Premiere Elements?
Premiere Pro supports GoPro's CineForm not sure about Elements. -
Well GoPro tell you to convert the files before editing. If I have understood it correctly, CineForm is what you get after this conversion.
http://gopro.com/support/articles/why-does-gopro-studio-convert-file-to-the-gopro-cineform-format -
The "end result" is H264 from Premiere Elements. But it turns out that there is something with the actual computer I'm using and it was probably a coincidence that made 30fps look more fluent. Both 24fps and 30fps look fluent on a different computer. I will reinstall Windows 7 or Windows 10 and the problems will surely go away. Sorry I didn't check better before bothering you guys.
I don't think it is possible to output 48fps from PRE?
About Cineform, isn't it a bit stupid to go from H264 to mpeg2 and then back to H264? -
Well, Cineform is not so much compressed, and easier to edit with. There's nothing wrong with Mpeg2.
Google announces support for 48fps and 60fps in YouTube
By flashandpan007 in forum Video Streaming DownloadingReplies: 1Last Post: 29th Jun 2014, 02:07 -
GoPro Canon FPS? what is best to shoot at? 24fps? 30fps? for editing?
By thestormtrooper in forum Newbie / General discussionsReplies: 14Last Post: 25th Feb 2014, 08:01 -
30fps --> 24fps WITHOUT pulldown
By agni451 in forum Video ConversionReplies: 4Last Post: 4th Apr 2012, 22:25 -
jackson shooting the hobbit films in 3d @ 48fps
By aedipuss in forum Latest Video NewsReplies: 24Last Post: 17th Mar 2012, 06:42 -
Convert 30fps to 24fps skipping every 5th frame?
By DragonQ in forum EditingReplies: 7Last Post: 29th Jan 2011, 03:11
