I have a video that was originally 23.976fps, but sped up to 25fps, including the audio. I can slowdown the video just fine, but I can't seem to slowdown the AAC audio.
eac3to requires some Nero plugins I don't have and have no idea how to get those. I could make a WAV with faad and then slow it down, but I still can't output a AAC file (AC3 will work). Also it might reduce the quality.
Audacity isn't an option either, because it casues background (white?) noice. Switching between WASAPI/MME/etc. doesn't work
Is there another way to slow the audio down (pitch+speed) while re-encoding as little as possible (AAC->AAC instead of AAC->WAV->AAC)?
nero aac codec is a free download. Although nero took it down from their site, many websites - even this one - still have it available to download
Is there another way to slow the audio down (pitch+speed) while re-encoding as little as possible (AAC->AAC instead of AAC->WAV->AAC)?Last edited by poisondeathray; 20th Mar 2015 at 17:25.
Yes, I'm sure
I've put the neroAacDec.exe, neroAacEnc.exe and neroAacTag.exe in the same folder as eac3to, but I'm getting these errors:
Code:G:\eac3to>eac3to a.aac an.m4a -slowdown AAC, 2.0 channels, 48kHz Decoding with DirectShow (Nero Audio Decoder 2)... Getting "Nero Audio Decoder 2" instance failed. Aborted at file position 262144. G:\eac3to>eac3to a.aac an.m4a -slowdown -nero AAC, 2.0 channels, 48kHz I'd like to use the Nero decoder, but it doesn't seem to work.
[AAC] AAC (avcodec), AAC (FDK) or HE-AAC (FDK)
By yopmail in forum AudioReplies: 10Last Post: 3rd Feb 2015, 21:17 -
Whats the difference between AAC (avcodec) and AAC Passthru in Handbrake?
By Nazomon in forum Newbie / General discussionsReplies: 1Last Post: 13th Dec 2014, 16:49 -
How to tell if audio is HE-AAC/AAC+/SBR
By Akai-Shuichi in forum AudioReplies: 3Last Post: 19th May 2013, 16:25 -
Which audio setting should I selected in XMedia? AAC or AAC (Faac)
By Greg2041 in forum AudioReplies: 3Last Post: 1st May 2013, 07:17 -
MKV AAC GUI Converter with Nero AAC Codec
By prijatelj.v in forum AudioReplies: 4Last Post: 26th Mar 2012, 08:41
