In general, is a tower computer with a fairly current, fairly fast video card better for playing ripped dvds and blurays from hard drive without "jerkiness" in the picture than a fairly new laptop?
Which aspects of the computer have the most to do with how smoothly the video plays back: amount of memory, cpu speed, quality of video card or video portion of motherboard (if video is built in to the motherboard only)?
No need to limit this to using a computer. I routinely play back movies from a WD-Live player, which files are playing back from an attached portable HDD, with no real-time computer involvement at all. These are sometimes DVD structures that have been copied to the portable drive, or else .MKVs, .AVI files, etc. Haven't done any Blu-Rays this way yet, but I probably could. So far, jerky playback has not been an issue. It is typically as good or better than live-streaming, as you'd see from Netflix. If the files are at higher than DVD resolution, this can also be better looking than what you'd get from NF, Hulu, etc.
Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
I've been using VMP Media player for a couple of years. It seems to work well with BD commercial discs and MKV backup of the same.
I do have AnyDVDHD running in the background.
I've used VLC, but it does require a bit of CPU power. VSO seems to work better. And you might try some of the other software players.Last edited by redwudz; 21st Mar 2015 at 22:09.
Best way to play Blu-ray rips from a hard drive
By idsane in forum Blu-ray RippingReplies: 10Last Post: 12th Apr 2012, 17:46 -
External Hard Drive to Bluray Player to Receiver to TV Problem :)
By LBSTEVE in forum AudioReplies: 1Last Post: 18th Jan 2012, 23:00 -
How to play HD Video from Hard Drive to Bluray
By jbitakis in forum Authoring (Blu-ray)Replies: 51Last Post: 14th Nov 2011, 16:43 -
Why don't my DVD copied onto hard drive play any more?
By kib in forum DVD RippingReplies: 1Last Post: 16th Nov 2010, 06:39 -
.mkv files on tv from Hard Drive through Bluray player to TV?
By xxnonamexx in forum Portable VideoReplies: 10Last Post: 7th May 2010, 12:00
