  1. I have got a *.mkv video file.
    At a first glance everything seems ok.
    I can play the video with VLC player in full length.
    However when I try to re-encode it (with various tools) the encoding stops around 1h and 20 min.
    I guess there is internally a hidden coding/format error in file.
    Is there a tool which is able to check the formal validity of a *.mkv video file?
    No.
    You could always try remux it with mkvmergegui. Add the mkv and make a new mkv.
    Or try repair it with meteorite.
    Or convert it with vlc. Under file -> convert /stream.
