  1. I have a smartphone that records full HD video in MP4 format. When I pull up the Mediainfo for the file it reports a really strange frame rate. Could this really be the case? Or is this another example of Mediainfo struggling?
    General
    Complete name                            : E:\MOV_0001.mp4
    Format profile                           : Base Media
    Codec ID                                 : isom
    File size                                : 418 MiB
    Duration                                 : 3mn 18s
    Overall bit rate                         : 17.7 Mbps
    Encoded date                             : UTC 2014-05-04 00:51:09
    Tagged date                              : UTC 2014-05-04 00:51:09
    ©xyz                                     : +30.1989-095.7297/
    Video
    Format profile                           : High@L4.0
    Format settings, ReFrames                : 1 frame
    Format settings, GOP                     : M=1, N=30
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Duration                                 : 3mn 18s
    Bit rate                                 : 17.5 Mbps
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Frame rate mode                          : Variable
    Frame rate                               : 29.719 fps
    Minimum frame rate                       : 14.859 fps
    Maximum frame rate                       : 32.585 fps
    Bits/(Pixel*Frame)                       : 0.284
    Stream size                              : 414 MiB (99%)
    Title                                    : VideoHandle
    Language                                 : English
  2. It's variable frame rate, very common for phones. It allows for longer exposures in darker conditions and also allows for fewer frames when the processing demands are too high. It's a perfectly logical solution for short clips that are meant to be shared by internet. It's hell to edit.
  3. Very interesting. I had no idea my phone was doing this. Fortunately, I don't acquire a lot of video via my phone. However, I pulled it into PPro and it seemed to handle just fine. Only doing simple cuts though. No advanced stuff like color correction or fast/slow motion. I also told PP to reinterpret the footage as 29.97 fps. Does this seem like a reasonable workflow?
  4. Premiere requires and will impose a constant framerate. The video you have will probably show blended and/or duplicated frames -- it's the nature of the beast. (That's the hell I referred to earlier.). you can edit as normal otherwise.
    Yes, it's a reasonable workflow.
