Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Results 1 to 14 of 14
    Mar 2015
    I recently took some video and when I downloaded the files, they play at 1/4 of the original speed and there's no audio track. I was able to take up up to speed with Adobe Premiere, but I've not been able to get sound. I've tested it in Quicktime, Adobe Premiere, and Windows Media Player to no avail.
    I've searched for an answer, but either this is unique or I'm asking the wrong questions.
    Here's the mediainfo:
    File: /Users/****/Desktop/BCP Class/P1010059.MP4
    Format: QuickTime/MPEG-4/Motion JPEG 2000 format
    Stream count: 2
    Duration: 00:13:06
    Bit rate: 5653 kb/s
    Meta info:
        compatible_brands: mp42avc1
        minor_version: 1
        creation_time: 2015-03-14 09:15:22
        major_brand: mp42
    Stream 0
    Type: video
    Codec: h264
    Codec profile: High
    FourCC: avc1
    Duration: 00:13:06
    Width: 1280
    Height: 720
    Sample aspect ratio: 1:1
    Display aspect ratio: 16:9
    Pixel format: yuv420p
    Frame rate: 29.98 fps
    Bit rate: 5518 kb/s
    Meta info:
        language: und
    Stream 1
    Type: audio
    Codec: aac
    FourCC: mp4a
    Duration: 00:13:06
    Bit rate: 127 kb/s
    Sample rate: 48000 Hz
    Sample format: s16
    Channel: 2
    Meta info:
        language: und
    Any help would be greatly appreciated.
    Aug 2010
    San Francisco, California
    Can you post a link to a file?
    Tried several players like vlc media player?
    Tried extract the audio with ffmpeg, mp4box or a gui like AoA Audio Extractor Basic?
    Mar 2015
    Here's a link. (That's actually the first of five files, but they all have the same problem.)
    I just downloaded and tried vlc media player, but not luck. I also tried extracting the audio with AoA Audio Extractor, and while the program successfully created an mp3 file, it was all silence when I listened to it. Do you think ffmpeg or mp4box will produce different results? I'm not too good with command line operations, but I can dig into the documentation if need be.
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    .....with a.....????
    Aug 2010
    I just downloaded the file. There is an AAC audio track, but it contains only silence. So either nothing was recorded or there was a problem when you copied the files from your device.
    Mar 2015
    So, does that mean the audio file is fine, its just silent, i.e., there was a problem with the microphone or some other hardware problem, rather than a file/software problem?
    Aug 2010
    Yup, the most straightforward answer is that you didn't record any audio. Try transferring the files again in case there was a hiccup.
  9. Member Cornucopia's Avatar
    This doesn't sound like the same sort of thing, but it might jog someone's memory in its similarity and bring about a solution:
    Recently doing edits to a few scores of Lossless files and then running the edited masters (via AVISynth script) through MeGUI for conversion to AVC-in-MP4. Inadvertently mis-scripted a few files where the file was a different FPS (faster or slower) than the script led you to expect. The output would end up much like the OP's: running slow (or, conversely, fast) while the audio wouldn't play or wouldn't play properly. However, in my case, it was clear from MediaInfo that the running times of the V vs. the A tracks didn't match (and they should have) so it was a clear indication of the script mis-representing and mishandling the data. That's what you get for reusing scripts without doing a preflight! My bad, won't happen again. Easy fix: re-encode the audio (from the original) and change the FPS header for the video then remux.
    Mar 2015
    Panasonic Lumix 7
    Mar 2015
    That's what I was afraid of. I'll try transferring again tonight.
  12. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Did you connect the camera to a computer or did you use a card reader?
    Mar 2015
    I used the SD card port on my laptop.
  14. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Strange. Now to me the IS a chance the recordings are corrupted on the camera.
    OUCH.
