Hi,
in this days I have try a new NLE called ***** ***** that I have use to export videos of my cats, one video have duration of 1 hour and 15 minutes and it is 468GB (the video part) because is and uncompressed HD
I have cats.avi and cats.wav
cats.avi is a YUY2 uncompressed video, interlaced, BT.709
cats.wav is a 48Khz L+R stereo audio file
Now I would like do with ffmpeg two types of encoding:
- one in MP4 using the best compression (crf?), in progressive mode, keeping HD 1920x1080, keeping bt.709, at a target size of 9 GB and keeping the 4:2:2 colorspace
and
-one in mpg SD suitable for DVD (4:2:0?), interlaced, scaling the original HD master (cats.avi) from HD to SD and convert into BT.601 at a target size of 4,7 GB
Kindly I wonder: what is the commandlines to do this?
thanks
mux those video and audio streams together, then use this Dmfs Avi to mp4.zip , you have one batch file there, so you drop one ini file and that avi onto that batch or simply call that batch, one pass only so far, so find your CRF before:
_AVI_to_MP4.BAT "some.INI" "your.avi"
where you just grab suitable INI in that folder and tweak it to what you need (with your Avisynth script etc), give it a new name, like my_new.INI and use it in that above command line
for DVD you use this dmfs from Vegas.zip where you drop that muxed avi into "DVD from HD interlaced.BAT", command line could be:
"DVD from HD interlaced.BAT" "your.avi"
do not ask about how to modify those batch scripts, if needed, I think you can do it yourself nowLast edited by _Al_; 19th Mar 2015 at 14:15.
VirtualDub, Xvid and target size
By lagartixa in forum Newbie / General discussionsReplies: 57Last Post: 8th Nov 2014, 07:11 -
Specifying target bitrate in ffmpeg conversion?
By pxstein in forum Newbie / General discussionsReplies: 13Last Post: 9th Sep 2013, 09:23 -
target container + codecs auto-detected when re-encoding with ffmpeg?
By pxstein in forum Newbie / General discussionsReplies: 1Last Post: 26th Jan 2013, 03:39 -
WinFF - Target File Size
By Simmons in forum Video ConversionReplies: 2Last Post: 13th Jan 2013, 07:27 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21
