Hi! I need some help, I have an .mkv video which has three audio streams embedded and two subtitles. Unfortunately the audio I want is not the standard one and neither of the subtitles are the right language.
So here is my question, how can I change the standard audio stream, so it always plays English one instead of Spanish and how can I make it standard to not use any of the embedded subtitles (I'll use subtitles from an .srt file)?
It's a gift for my technology impaired father, hence the necessity to make it work the correct way, straight away
You can use mkvmergegui (included in mkvtoolnix). Open the mkv. Click on the audio track and set it to the default track and the other no. Make a new mkv. Test play it.
I guess you can use mkvpropedit also and you can fix without having to make a new mkv. But it's a command line utility. No gui.
Another option would be to remove additional audio and subtitle tracks and make a new mkv. -
Thanks worked exactly like I wanted!
But now another question, the subtitles I found aren't sync correctly, is there a way to sync and embedd them into the mkv? Can I do it in the same program? -
You can use subtitle edit to sync your srt file against the video. Then mux it back to the mkv with mkvmergegui.
fixing audio sync without changing the video/audio quality of mp4 video
By aruwin in forum AudioReplies: 3Last Post: 8th Aug 2014, 00:10 -
Changing aspect ratio of subtitles
By kodec in forum SubtitleReplies: 4Last Post: 13th Mar 2014, 12:41 -
Changing video cards from GT 520 to GT 545 improved audio Tremendously?
By MarcMiller in forum ComputerReplies: 7Last Post: 13th Feb 2012, 15:51 -
Audio sync issue, Virtualdub, old video clips changing frame rate
By litmus in forum Video ConversionReplies: 1Last Post: 19th Sep 2011, 12:35 -
Covert a .mp4 movie's audio alone to mp3 without changing the video quality
By ckarvnd in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 12:02
