I find with my LG Blu-Ray player when I make a 4:3 DVD, it always stretches it. No zoom setting on the TV or the player fixes this.
One solution is to encode the DVD as pillar-boxed 16:9 with a 4:3 image in the center but my understanding is this robs quality from the image to devote to the pillarboxing.
Is there some way to ensure that any player/TV will correctly size 4:3 video?
Nothing to do with the blu-ray player, but everything with the software settings. You need to make sure the aspect ratio is 4:3 / full screen / standard or whatever other terminology the burning software uses.
If a commercial (store-bought) 4:3 movie plays incorrectly jagabo's answer is best -- check the setup on your hardware. If it does play correctly, use newpall's solution and check your software.
Have you tried playing a commercial 4:3 disk ?
I would concur with jagabo since there could well be a player setting, pretty much hidden, that controls the screen display since the natural default would be wider than 4:3
As an example, I have a upscaling dvd recorder/player and that defaults to full screen over hdmi. But there is an alternative setting for 4:3 -
I do a lot of service calls for setting up new lcd tvs including lg and they all have a zoom feature,best to read your manual on how to set it,most tv controls you can zoom right away,other sets you have to go into the setup to make sure that 4:3 is set to display properly.
I have seen this with a Philips DVD (yes DVD and not BD) player I own that uses an HDMI connection to my TV. My TV (Vizio) lacks a button on the remote control to force 4:3 playback so I had to fix this on the DVD player. I tried a bunch of things and the only thing that works is to set the DVD player for 480p output. This somehow preserves 4:3 aspect ratios. If I have a widescreen DVD I'm watching, I leave the DVD player output at 1080p.
We have an LG BD650 Blu-ray player set to upscale 4:3 DVD with pillarboxing. It works just fine.
How to determine the correct aspect ratio?
By TeNSoR in forum Newbie / General discussionsReplies: 6Last Post: 19th Mar 2014, 06:33 -
How to Correct Aspect Ratio of output
By sandergm in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 3rd Feb 2014, 21:25 -
Proper way to determine if the aspect ratio is correct
By edong in forum Video ConversionReplies: 9Last Post: 7th Oct 2012, 17:31 -
How to ensure some frames are in correct aspect ratio?
By ANOther1676 in forum EditingReplies: 1Last Post: 30th Apr 2011, 22:16 -
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11
