I cannot figure out how to use the blend layers filter in Virtualdub. It always says that I only have one video clip. I loaded two clips and selected a region that spans through the attachment point, but nothing works. Since Virtualdub does not have layers like a NLE (ie Adobe Premiere) I am very confused.
Not sure if this is what you need, but it's from the now defunct VirtualDub site.
Look at post #2 from dloneranger.
http://forums.virtualdub.org/index.php?act=ST&f=7&t=21587&hl=blend,and,layers& -
Yes. That looks like the info I need. A complicated way to force VirtualDub to do some pseudo layering. Thanks for the reply.
I'm trying to figure this out as well, and now that forum is down.
Help, please?
Is this what you are trying to do?
https://youtu.be/2MWoVY9mYbk -
Unfortunately, no.
What I'm trying to do is layer two videos on top of each other, but I don't think VirtualDub can do this.
Best luma brightening filter for VirtualDub?
By callmebc in forum EditingReplies: 19Last Post: 27th Jan 2013, 15:25 -
Gradation Curves VirtualDub filter v1.45
By BBugsBunny in forum RestorationReplies: 27Last Post: 22nd Mar 2012, 18:23 -
VirtualDub Deinterlace Filter yadif vs blend
By kreg in forum Capturing and VCRReplies: 1Last Post: 22nd Jul 2011, 13:42 -
VirtualDub: Layer Filter
By creamcone in forum EditingReplies: 6Last Post: 26th Dec 2010, 12:27 -
VirtualDub filter
By nic3 in forum EditingReplies: 6Last Post: 30th Sep 2010, 10:48
