I would like to purchase a Blu-Ray player for my parents...but I already have a bunch of DVD-Rs movies that I have burned over the years; so, I was thinking that I could purchase Blu-Ray movies and also burn some Blu-Ray movies of my own from HQ .MKV files I have.
Can someone recommend a Blu-Ray player (HDMI) that can read both "BD-R" & "DVD-R" formats?
This looked promising...but I dont think it is BD-R: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=8915333&CatId=4670
Any help is much appreciated...thank you
Some older BluRay players did have problems with BD-R LTH discs. This should no longer be the case.
Any modern BluRay player should be able to read any consumer burnable DVD and BD discs without problems, but as always, improperly made or out of spec or low quality discs may have problems that correctly made good quality discs do not.
I'm not a huge fan of their stuff because I think the company is in some ways consumer hostile, but I've got a 2 year old Samsung 3D BluRay player and I've yet to have to choke on a DVD I've burned, but it is a little bit fussy on BD-R LTH discs. It has no problem with non-LTH BD-R discs. I'd honestly expect the Philips in your link to be fine. I've used their DVD players for years and never had a problem with media I've burned. -
...plus good burning software used with a burner that is not worn out.
Personally, I would not take a chance buying a refurbished Blu-Ray player online.
[Edit]Also, be aware that although many Blu-Ray players can play MKV media files, there is no guarantee that they will play every MKV file you throw at them. Blu-Ray players that can act as media players all have restrictions on what kind of audio, video, and subtitles are allowed for playback in an MKV container, assuming they support the MKV container.Last edited by usually_quiet; 17th Mar 2015 at 14:59.
And even if you convert the MKV files to Blu-ray format, you might still be stymied by Cinavia in some of them. Any new player, certified after February of 2012, is required to detect the Cinavia signal and, if detected, will stop audio playback from Blu-ray format video burned to a disc. Its just another gotcha you should be aware of.
Blu-ray player to play "X-Men: Days of Future Past" blu-ray
By nekros111 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 6th Sep 2015, 03:06 -
How to convert "Still Image" to "AVC file" (like as Godzilla Blu ray Menu)
By ningnong132 in forum Video ConversionReplies: 2Last Post: 8th Sep 2014, 04:23 -
DVDFab "convert blu ray to dvd"
By clashradio in forum Blu-ray RippingReplies: 4Last Post: 12th Jun 2014, 14:24 -
AVCHD/"Blu-ray" fails to play on Sony X Box. Should it?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 9Last Post: 24th Aug 2010, 18:34 -
Ask for Tip of a tool just like "Blu-ray to DVD II Pro"
By jjulio1 in forum Blu-ray RippingReplies: 0Last Post: 5th Aug 2010, 08:17
