hey guys
is there any cool lite tool where we can trim video, add an audio track and save them separately (or together), mainly without re-encoding?
i have avidemux and i love it, but now i need to place an audio file and adjust its position to the video, makes some cuts and save the audio file (need to trim the video also) without any re-encoding.
anyone know a tool for that?
Not quite sure if I follow but if I take this
Mux the video and audio with MKVMergeGUI.i need to place an audio file and adjust its position to the video, makes some cuts and save the audio file (need to trim the video also) without any re-encoding.
Adjust the audio position using shift in AviDemux.
Make the cuts and save video and audio (copy) to a MKV.
If you only need the audio de-mux it with MKVExtractGUI2. -
ill take a look at MKVMergeGUI
but what im after is basically the timeline of adobe premiere, when you have the video file on a track, several audio tracks, all visible in a timeline, where you can move the play-head front and back and see the video / hear the audio, move the files along the timeline to adjust their position, make cuts (on the timeline) and then export both the video and audio, separately, without having to re-encode.
i checked aviutl but it seems fairly complex
something simpler and to the point would be great -
sounds a bit weird i have to re-encode.
in avidemux i can cut a portion of a video and save it without re-encoding it.
i can do the same with audio in any audio editor, right?
the only thing i'd need in a program where i can visual see the video and audio on a timeline and be able to adjust their position.
it sounds like i should be able to then make cuts to match the start of the audio and the start of the video and just save the portion id like without re-encoding, like i can do for video in avidemux and audio in any audio editor.
just i need the timeline feature.
or am i looking at this wrong? -
I'm pretty sure you need an advanced/nle editor if you easily want to cut and trim both video and audio tracks. Like for example sony moviestudio or even windows moviemaker. I think moviestudio has a smart rendering so it shouldn't reconvert video if you output as same format.
want to add prop in video dont have a clue
By gurmet in forum EditingReplies: 2Last Post: 26th Jul 2012, 01:22 -
Is there ANYthing that will trim h.264 flv's without audio sync issues?
By AshleyQuick in forum Newbie / General discussionsReplies: 4Last Post: 29th Mar 2012, 09:07 -
Looking for a BD Authoring software that dont re-encode MPEG2 Files
By faramith in forum Authoring (Blu-ray)Replies: 11Last Post: 14th Dec 2011, 04:39 -
By AshleyQuick in forum Newbie / General discussionsReplies: 4Last Post: 18th Nov 2011, 00:28 -
How do I trim audio with AVIsynth?
By Nagashi in forum AudioReplies: 4Last Post: 2nd Oct 2011, 10:13
