Results 1 to 10 of 10
    Jan 2014
    India
    hi can some genius tell me what filters were used on this rip by screen shot and sample added hopefully with value as well Example sharpen(0.3) like this please
    and this is another RIP please tell me for this as well
    http://someimage.com/BjJi
    Rip Sample
    source dvd sample
  2. I doubt anyone can tell you anything specific. You don't even have the source DVD to compare it against, do you? Ask the guy that made it.
    Jan 2014
    India
    Ya i asked there won't tell mi as there are releaser group i got the dvd source sample added
    source dvd sample
  4. Even with before and after samples nobody can tell you exactly what filters and settings were used because there are many ways to achieve similar results.
  5. I noticed one thing he did. The DVD company converted from Film to PAL by the idiotic method of adding a duplicate frame every second, which results in a slight stutter once a second. Your warez guy removed the duplicate frames to get it back to 24fps. Other than that, don't know, don't care.
  6. Banned
    Oct 2014
    Northern California
    Yes idiocy is a world-wide phenomenon.
    Jan 2014
    India
    so how to get similar result then what filter would that be
  8. It looks to me like the did something like:
    Crop(0,70,-0,-70)
    BicubicResize(720,304)
    TDecimate(cycle=25, cycleR=1)
    lsfmod(strength=100)
    Jan 2014
    India
    Crop(0,70,-0,-70)
    No denoise need it?
    And would be best script for upscaling this source to 1280x544?
  10. The source is pretty clean so I don't think you need any noise reduction -- a little noise is your friend, it prevents posterization artifacts. I would use Mpeg2Sourc("VTS_03_2.demuxed.d2v", CPU2="ooooxx") to open the video -- for its deringing. Upscale it if you want. Try nnedi3_rpow2(2, cshift="Spline36Resize", fwidth=720, fheight=544). Be sure to encode with enough bitrate.
