Results 1 to 27 of 27
  1. *EDIT*
    Here:
    *** Link Removed ***
    Thanks for cutted parts in attached here:
    https://forum.videohelp.com/threads/370776-Mpeg2-Xvid-Xvid4Psp-question-about-de-interl...=1#post2379987
    I have to encode some Mpeg2 like this:
    General
    Complete name               : D:\Temp\05\05_OK.mpg
    Format                      : MPEG-PS
    File size                   : 1.37 GiB
    Duration                    : 20mn 17s
    Overall bit rate mode       : Variable
    Overall bit rate            : 9 683 Kbps
    Video
    Format                      : MPEG Video
    Format version              : Version 2
    Format profile              : Main@Main
    Format settings, BVOP       : Yes
    Format settings, Matrix     : Default
    Format settings, GOP        : Variable
    Format settings, picture st : Frame
    Duration                    : 20mn 17s
    Bit rate mode               : Variable
    Bit rate                    : 9 300 Kbps
    Width                       : 720 pixels
    Height                      : 576 pixels
    Display aspect ratio        : 4:3
    Frame rate                  : 25.000 fps
    Standard                    : PAL
    Color space                 : YUV
    Chroma subsampling          : 4:2:0
    Bit depth                   : 8 bits
    Scan type                   : Interlaced
    Scan order                  : Top Field First
    Compression mode            : Lossy
    Bits/(Pixel*Frame)          : 0.897
    Time code of first frame    : 00:00:00:00
    Time code source            : Group of pictures header
    Stream size                 : 1.31 GiB (95%)
    Color primaries             : BT.601 PAL
    Transfer characteristics    : BT.470 System B, BT.470 System G
    Matrix coefficients         : BT.601
    Audio
    ID                          : 189 (0xBD)-128 (0x80)
    Format                      : AC-3
    Format/Info                 : Audio Coding 3
    Mode extension              : CM (complete main)
    Format settings, Endianness : Big
    Muxing mode                 : DVD-Video
    Duration                    : 20mn 17s
    Bit rate mode               : Constant
    Bit rate                    : 256 Kbps
    Channel(s)                  : 2 channels
    Channel positions           : Front: L R
    Sampling rate               : 48.0 KHz
    Bit depth                   : 16 bits
    Delay relative to video     : 24ms
    Stream size                 : 37.1 MiB (3%)
    This is a SatRip from SkyIT Registered using scart into a DVD-RW. After that i have cutted parts and use VideoRedo to obtain this final mpeg to convert.
    I need some info about the interlaced.......... i have load this file on xvid4psp 5.10.346.0 and wait to analizing for interlace but nothing it's founded.. i have posted a screenshot here:
    https://forum.videohelp.com/images/imgfiles/Qp15e4f.png
    *EDIT*
    This screenshot it's related to previous episode i have posted the mediainfo... but for all episode i obtain the same result after auto-analizing of interlaced or not.....
    I already have tryed to convert another similar file (the first episode ) whit this auto detected setting for interlace and my pc have completed the encoding in about 40minutes.
    At this point........ you can suggest to me to add manually a de-interlace ?? Or it's not needed ?? I have try to watch the first .avi and i thinks the quality it's good on my tv... but if in next episode i can obtain a better result only after added manually de-interlace filter suggest to me...
    Thanks in advance.......
  2. You have not indicated that you see any interlacing artifacts during playback. Do you? You can cut out a short section with VideoRedo and post it if you want others to look.
  3. Originally Posted by smrpix View Post
    Lol...... you are absolutely right.... i have tryed to watch the source and i don't look artifacts or similar but i'm not a expert and I think I can make mistakes in evaluating this source (At this point i thinks i have used the wrong section... i can open this on newbie section for example).
    Otherwise yes..... i can create this parts and for example load/upload on some file hosting service... ok ??
    One minutes ?? Two minutes ?? 5 minutes ?? Or it's enought about 30 seconds im mpeg 2 ?
    *EDIT*
    I have tryed to cut a 2minutes of video from beginning... it's a 138MB Files.
    My Upload Speed (Italian ADSL) it's very shit.... it's for you it's same a less duration it's better
    Otherwise i need to use a file hosting for make possibly to you to watch the real source.... because if i upload on youtube (for example) i don't thinks you can verify the original source because youtube make a conversion before to publish the video...
    *EDIT 2*
    Ok.. for upload this:
    General
    Complete name               : D:\Temp\05\Small_Parts_4_Friends.mpg
    Format                      : MPEG-PS
    File size                   : 139 MiB
    Duration                    : 2mn 0s
    Overall bit rate            : 9 682 Kbps
    Video
    Format                      : MPEG Video
    Duration                    : 2mn 0s
    Width                       : 720 pixels
    Height                      : 576 pixels
    Standard                    : PAL
    Color space                 : YUV
    Bit depth                   : 8 bits
    Stream size                 : 132 MiB (95%)
    Audio
    Format                      : AC-3
    Duration                    : 2mn 0s
    Bit rate                    : 256 Kbps
    Bit depth                   : 16 bits
    Stream size                 : 3.66 MiB (3%)
    I need about one hours.... go to make dinner and back to post mirror for you.....
  4. 10 seconds with steady movement will be plenty. We don't need much to tell if it's interlaced or not.
  5. Originally Posted by manono View Post
    Azz
    This is the first 2 minutes........... if it's not good i can try to upload 10seconds in a steady moments
    Link for 158MB File:
    http://www.uploadmagnet.com/jznlqcug72iq/Small_Parts_4_Friends.mpg
    *EDIT*
    mmmmmmmmmm... apparently uploadmagnet it's a shitty service
  6. I can't even figure out how to download it. Maybe try again, this time uploading it to this site using the 'Upload files/Manage attachments' button. Ten seconds of it.
    Yes, apparently.
  7. Originally Posted by manono View Post
    Yes, apparently.
    Lol
    I try to using different host.............
  8. Why don't you use videohelp.com as a host ?
    Content is not interlaced . Often the content will tell you right away what it should be. An American TV show / Drama / Sitcom will usually not be interlaced
    Here is a cut sample in case anyone doesn't want do download the unecessary 138MB from a crappy host
    (ignore the 1st duplicate, it was from the way sample was cut - the duplicate isn't there in the larger file)
  9. The video is encoded interlaced but the content of the frames is progressive. You can treat it as progressive video.
  10. Originally Posted by poisondeathray View Post
    Lol.....i'm stay now to upload the same large file on mirrorcreator.....................ok...i canceled this upload
    mmmmmmmmmmmm...... at this point i can know if file it's interlaced read only the mediainfo but i ever need to verify manually ?
    Very Well... at this point the autoidentify of Xvid4psp working as good
    Thanks also to you for this another fadeback
    @X ALL:
    And sorry for all for large file......... at this point i can continue to encoding all nine episode of this 4rd season
    *Only for purpose fun*
    After i look the file it's ever in upload (now apparently it's been upload correctly) i have maked another little cutter parts from 05.mpeg.
    This a 30seconds whit some steady movement:
    http://www.mirrorcreator.com/files/1Y0OLM0G/small_steady_parts.mpg_links
  11. Great........... all episodes it's now in XVID on my HD!
    A xvid mediainfo:
    General
    Complete name               : D:\Temp\05_OK.avi
    Format                      : AVI
    Format/Info                 : Audio Video Interleave
    File size                   : 258 MiB
    Duration                    : 20mn 17s
    Overall bit rate            : 1 778 Kbps
    Writing application         : VirtualDubMod 1.5.10.3 | www.virtualdub-fr.org || (build 2550/release)
    Writing library             : VirtualDubMod build 2550/release
    Video
    Format                      : MPEG-4 Visual
    Format profile              : Advanced Simple@L5
    Format settings, BVOP       : 1
    Format settings, QPel       : No
    Format settings, GMC        : No warppoints
    Format settings, Matrix     : Default (H.263)
    Codec ID                    : XVID
    Codec ID/Hint               : XviD
    Duration                    : 20mn 17s
    Bit rate                    : 1 640 Kbps
    Width                       : 720 pixels
    Height                      : 408 pixels
    Display aspect ratio        : 16:9
    Color space                 : YUV
    Bit depth                   : 8 bits
    Scan type                   : Progressive
    Bits/(Pixel*Frame)          : 0.223
    Stream size                 : 238 MiB (92%)
    Writing library             : XviD 1.2.1 (UTC 2008-12-04)
    Audio
    Format                      : MPEG Audio
    Format version              : Version 1
    Format profile              : Layer 3
    Codec ID                    : 55
    Codec ID/Hint               : MP3
    Duration                    : 20mn 17s
    Bit rate                    : 128 Kbps
    Stream size                 : 18.6 MiB (7%)
    Alignment                   : Aligned on interleaves
    Interleave, duration        : 40 ms (1.00 video frame)
    Interleave, preload duratio : 504 ms
    Writing library             : LAME3.99r
    Encoding settings           : -m s -V 4 -q 2 -lowpass 17 -b 128
    This time i use VideoHelp hosting services.....
    Ah... on option of xvid4psp i have raise the value to 25% of entire files for analizing the interlace........ i take a little more wait when i load the file but i thinks it's better if in some case i need to convert a source interlaced in next future.
  12. I have also a little problems whit this 05.mpeg and i can't understand what's appened during encoding:
    I have choose to use about 1500bitrate on encoder settings................ and respect a size of output file to 240MB...... but look the mediainfo!
    Because the bitrate using it's 1640 ??
    Duration : 20mn 17s
    And look the log of conversion:
    Encoding video to: C:\Temp\0014.avi
    XviD (1.2.2) 1512kbps 720x408 25.000fps (30428 frames)
    Or another log section:
    xvid_encraw.exe: -pass2 "C:\Temp\0014_1.log" -bitrate 1512 -qtype 0 -vhqmode 4 -nopacked -bvhq -max_bframes 1 -lumimasking -imin 1 -pmin 1 -bmin 1 -threads 4 -i "C:\Temp\0014.avs" -avi "C:\Temp\0014.avi"
    The bitrate i choose to use it's 1512......... but it's 1640 used....... because ??
    Again my setting it's at begin of log:
    VEncodingMode: TwoPass
    VideoCodec: MPEG2 > XviD (1.2.2)
    VideoBitrate: 9300 > 1512
    I can upload the complete log......... apparently it's all setteng what i want to obtain.. but after the encoding complete i obtain a totally different output file whit no bitrate respected and no filezie respected... because ?
  13. Audio plus video plus muxing overhead?
  14. Originally Posted by manono View Post
    mmmmmmmm..... we can hypothesise.... how i can check this ?
    Ah... i have also installed GordianKnot (GordianKnot.RipPack.0.35.0.Setup.2.exe) and i have tryed to encoding the 05_OK.mpeg from here and same here, i have choose to obtain a 240MB file and i have obtain a bigger file like encoding obtained yesterday using xvid4psp (but GorkianKnot it's much better faster!!!!)... this is full log:
    15/03/2015 16:07:25: Job " 1 - 05_OK.avi" started.
    o  Converti sorgente -> MP3:  D:\Temp\05\05_OK T01 2_0ch 256Kbps DELAY 24ms.ac3
    o  Xvid - Prima Pass:         D:\Temp\05\05_OK.avs
    o  Xvid - Seconda Pass:       D:\Temp\05\05_OK.avs
    o  Unisci Audio.
    Fine Job 1 ( 1 - 05_OK.avi).
    _______________________________________________________________________________________________________________________
    Gordian Knot
    Encoding Job Data:
    Type:               EncXvid_All
    Container:          Audio-Video Interleave (AVI)
    Number:             1
    Name:                1 - 05_OK.avi
    Platform:           WinUnknown (6.1.7601).2
    Files:
    VirtualDubModExe:   C:\PROGRA~2\GORDIA~1\VirtualDubMod\VirtualDubMod.exe
    NandubExe:          C:\PROGRA~2\GORDIA~1\nandub\Nandub.exe
    AviFinal:           D:\Temp\05\05_OK.avi
    AviMovie:           D:\Temp\05\05_OK_Movie.avi
    AviCredits:         D:\Temp\05\05_OK_Credits.avi
    MovieFS:            D:\Temp\05\05_OK.avs
    CreditsFS:
    Log :               D:\Temp\05\05_OK.log
    Stats:              D:\Temp\05\05_OK.stats
    Ecf :               D:\Temp\05\05_OK.ecf
    Options:
    Quality/DRF:        0
    CreditsStart:       0
    UseEcf:             1
    CreditsIVTC:        0
    CreditsAppend:      0
    DeleteInterm.:      0
    EnforceBitrate:     0
    AntiShit:           0
    Calculator:
    VideoSize:          226744 kbyte.
    Audio1Size:         19015 kbyte.
    Audio2Size:         0 kbyte.
    Overhead:           0 kbyte.
    AviSize:            245760 kbyte (240 mbyte).
    FilesSize:          0 kbyte.
    TotalSize:          245760 kbyte (240 mbyte).
    Interleaving:
    Bitrate:            1526 k(=1000)Bits/s
    Frames:             30428
    FPS:                25.000
    Duration:           020:17
    Quality:            0.212 bits/(pixel*frame).
    CompCheck3:         0.000 bits/(pixel*frame).
    CompCheck5:         0.000 bits/(pixel*frame).
    Resolution:         720 x 400
    Audio 1:
    Mode:               ac3 -> mp3
    SourceFile:         D:\Temp\05\05_OK T01 2_0ch 256Kbps DELAY 24ms.ac3
    WavFile:            D:\Temp\05\05_OK T01 2_0ch 256Kbps DELAY 24ms.wav
    Mp3File:            D:\Temp\05\05_OK T01 2_0ch 256Kbps DELAY 24ms.mp3
    OggFile:            D:\Temp\05\05_OK T01 2_0ch 256Kbps DELAY 24ms.ogg
    OggQuality:         0.200
    OggLanguage:        English
    Azid:               -c normal
    Lame:               -h --cbr -b 128
    Delay:              24
    Interval:           1
    Preload:            500
    Mux:                1
    Recalc:             1
    DeleteWav:          1
    Audio 2:
    none.
    16:07:25: Started Transcoding Audio.
    16:07:25: Using "BeSweet" to transcode D:\Temp\05\05_OK T01 2_0ch 256Kbps DELAY 24ms.ac3
    CommandLine: "C:\PROGRA~2\GORDIA~1\BeSweet\BeSweet.exe" -core( -input "D:\Wilfred\05\05_OK T01 2_0ch 256Kbps DELAY 24ms.ac3" -output "D:\Temp\05\05_OK T01 2_0ch 256Kbps DELAY 24ms.mp3" -logfile "D:\Temp\05\05_OK T01 2_0ch 256Kbps DELAY 24ms.log" ) -ota( -hybridgain ) -azid( -c normal )  -lame( -h --cbr -b 128 )
    16:08:29: Finished. Duration: 1 minuto, 4 secondi.
    16:08:29: Audio Done.
    16:08:29: MP3-File-Size is 19020 kb.
    16:08:29: Audio 1, determined:     19020 kb
    16:08:29: Audio 1, calc:           19015 kb
    16:08:29: New Bitrate for Movie = 1526 k(=1000)Bits/s
    Adding this script to C:\PROGRA~2\GORDIA~1\VirtualDubMod\LastJob.vcf :
    // $job "XviD First Pass"
    // $input "D:\Temp\05\05_OK.avs"
    // $output "D:\Temp\05\05_OK_Movie.avi"
    // $state 0
    // $start_time 0 0
    // $end_time 0 0
    // $script
    VirtualDub.Open("D:\\Temp\\05\\05_OK.avs",0,0);
    VirtualDub.video.SetDepth(24,24);
    VirtualDub.video.SetMode(1);
    VirtualDub.video.SetFrameRate(0,1);
    VirtualDub.video.SetIVTC(0,0,-1,0);
    VirtualDub.video.SetRange(0,0);
    VirtualDub.video.SetCompression(0x64697678,0,10000,0);
    VirtualDub.video.SetCompData(10440,"AQAAAKgEAABhwgIARDpcV2lsZnJlZFwwNVwwNV9PSy5zdGF0cwBcADAANQBfAE8ASwAuAHMAdABhAHQAcwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkAEAAE1QRUc0IEFkdmFuY2VkIFNpbXBsZSBAIEw1AAAgAFMAaQBtAHAAbABlACAAQAAgAEwANQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHgAAAChVc2VyIGRlZmluZWQpAABmAGkAbgBlAGQAKQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAAAAAAAIERITFRcZGxESExUXGRscFBUWFxgaHB4VFhcYGhweIBYXGBocHiAjFxgaHB4gIyYZGhweICMmKRscHiAjJiktEBESExQVFhcREhMUFRYXGBITFBUWFxgZExQVFhcYGhsUFRYXGRobHBUWFxgaGxweFhcYGhscHh8XGBkbHB4fIQAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAIAAACWAAAAZAAAAAAAAAABAAAAAAAAAAQAAAADAAAAAQAAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAGQAAAD0AQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAZAAAAGQAAAABAAAACgAAAAEAAAAUAAAAAAAAAAAAAAAFAAAABQAAAAUAAABADQMAAAAAAAEAAAAAAAAAFAAAACkAAAACAAAAAAAAAAAAAACAAAAAvksAAAAAAAAGAAAAAQAAAAAAAAABAAAAAQAAAAEAAAAAAAAALAEAAAAAAAABAAAAHwAAAAEAAAAfAAAAAQAAAB8AAAABAAAAAgAAAAAAAAAAAAAAAAAAAAEAAAAAAAAAAQAAAP8BAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA");
    VirtualDub.video.filters.Clear();
    VirtualDub.subset.Delete();
    VirtualDub.SaveAVI("D:\\Temp\\05\\05_OK_Movie.avi");
    VirtualDub.Close();
    // $endjob
    // $done
    16:08:29: Started   Xvid - First Pass: D:\Temp\05\05_OK.avs
    16:16:24: Finished  Xvid - First Pass: Duration: 7 minuti, 54 secondi.
    16:16:24: Trying to open Log-file.
    16:16:24: Success: Log-file open.
    16:16:24: Encoded:  30428 Frames.
    16:16:24: Speed:    64.132 Frames per Second.
    16:16:24: New target size =    226739 Kb
    // $job "XviD Second Pass"
    // $state 0
    // $start_time 0 0
    // $end_time 0 0
    // $script
    VirtualDub.video.SetCompData(10440,"AgAAAKgEAACzdQMARDpcV2lsZnJlZFwwNVwwNV9PSy5zdGF0cwBcADAANQBfAE8ASwAuAHMAdABhAHQAcwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkAEAAE1QRUc0IEFkdmFuY2VkIFNpbXBsZSBAIEw1AAAgAFMAaQBtAHAAbABlACAAQAAgAEwANQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHgAAAChVc2VyIGRlZmluZWQpAABmAGkAbgBlAGQAKQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAAAAAAAIERITFRcZGxESExUXGRscFBUWFxgaHB4VFhcYGhweIBYXGBocHiAjFxgaHB4gIyYZGhweICMmKRscHiAjJiktEBESExQVFhcREhMUFRYXGBITFBUWFxgZExQVFhcYGhsUFRYXGRobHBUWFxgaGxweFhcYGhscHh8XGBkbHB4fIQAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAIAAACWAAAAZAAAAAAAAAABAAAAAAAAAAQAAAADAAAAAQAAAAEAAAAAAAAAAPkbAAASegAAAAAAAQAAAAAAAAAAAAAAAAAAAGQAAAD0AQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAZAAAAGQAAAABAAAACgAAAAEAAAAUAAAAAAAAAAAAAAAFAAAABQAAAAUAAABADQMAAAAAAAEAAAAAAAAAFAAAACkAAAACAAAAAAAAAAAAAACAAAAAvksAAAAAAAAGAAAAAQAAAAAAAAABAAAAAQAAAAEAAAAAAAAALAEAAAAAAAABAAAAHwAAAAEAAAAfAAAAAQAAAB8AAAABAAAAAgAAAAAAAAAAAAAAAAAAAAEAAAAAAAAAAQAAAP8BAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA");
    VirtualDub.Close();
    // $endjob
    // $done
    16:16:24: Started   Xvid - Second Pass: D:\Temp\05\05_OK.avs
    16:26:59: Finished  Xvid - Second Pass: Duration: 10 minuti, 35 secondi.
    16:26:59: Speed:    47.900 Frames per Second.
    // $job "DivX5 Append"
    // $input "D:\Temp\05\05_OK_Movie.avi"
    // $output "D:\Temp\05\05_OK.avi"
    // $state 0
    // $start_time 0 0
    // $end_time 0 0
    // $script
    VirtualDub.Open("D:\\Temp\\05\\05_OK_Movie.avi",0,0);
    VirtualDub.RemoveInputStreams();
    VirtualDub.stream[0].SetSource("D:\\Temp\\05\\05_OK T01 2_0ch 256Kbps DELAY 24ms.mp3",0x00000202,0);
    VirtualDub.stream[0].SetMode(0);
    VirtualDub.stream[0].SetInterleave(1,500,1,0,24);
    VirtualDub.stream[0].SetClipMode(1,1);
    VirtualDub.stream[0].SetConversion(0,0,0,0,0);
    VirtualDub.stream[0].SetVolume();
    VirtualDub.stream[0].SetCompression();
    VirtualDub.video.SetMode(0);
    VirtualDub.video.SetCompression();
    VirtualDub.SaveAVI("D:\\Temp\\05\\05_OK.avi");
    VirtualDub.Close();
    // $endjob
    // $done
    16:26:59: Started   Muxing Audio.: D:\Temp\05\05_OK_Movie.avi
    16:27:08: Finished  Muxing Audio.: Duration: 9 secondi.
    16:27:08: Done.
    16:27:08: Movie = D:\Temp\05\05_OK.avi
    Total Encoding Time: 19 minuti, 43 secondi.
    15/03/2015 16:27:08: Job " 1 - 05_OK.avi" finished.
    And this is the MediaInfo of 05_OK.avi encoding by GK:
    General
    Complete name               : D:\Temp\05\05_OK.avi
    Format                      : AVI
    File size                   : 256 MiB
    Duration                    : 20mn 17s
    Overall bit rate            : 1 761 Kbps
    Writing application         : VirtualDubMod 1.5.10.2 (build 2540/release)
    Writing library             : VirtualDubMod build 2540/release
    Video
    Format settings, BVOP       : 2
    Codec ID                    : XVID
    Duration                    : 20mn 17s
    Bit rate                    : 1 624 Kbps
    Width                       : 720 pixels
    Height                      : 400 pixels
    Color space                 : YUV
    Bit depth                   : 8 bits
    Bits/(Pixel*Frame)          : 0.225
    Stream size                 : 236 MiB (92%)
    Writing library             : XviD 73
    Audio
    Format                      : MPEG Audio
    Mode                        : Joint stereo
    Mode extension              : MS Stereo
    Codec ID                    : 55
    Codec ID/Hint               : MP3
    Duration                    : 20mn 17s
    Bit rate                    : 128 Kbps
  15. Then it's not as I speculated. Are you using the XviD that comes with AutoGK? Also, sometimes oversized AVIs can result from just installing a new XviD without removing the old one. My next suggestion would be to use Add/Remove Programs to completely remove the old XviD before then installing a new one. especially if you install the one included with AutoGK. And if using AutoGK you should use the one that's included.
  16. Originally Posted by manono View Post
    Wait... i need to explain. I have this little trouble only whit this 05.mpeg...... i have also encoded the remain 9 episodes and the filesize has ben respected whitout problems
    It's only about 15MB much bigger........ i have installed the GK whitout the codec pack (i use K-Lite Codec Pack installed) and i never installed AutoGK, on this PC i have previously installed:
    - MeGUI : I using it for x264
    - At in this last 5 days i have first installed Xvid4PSP and yesterday this GK whitout the codec pack (http://sourceforge.net/projects/gordianknot/files/Gordian%20Knot%20Codec%20Pack/GK%20C...p.exe/download) i not installed the codec pack just for not install double codec....
    *EDIT*
    Whit DRF Analysis output from AVInaptic i can find out if the file contain OverHead parts ?
    Info sul file
    Nome                        05_OK_GK.avi
    Data                        Sun, 15 Mar 2015 16:27:08 +0100
    Dimensione                  267,970,560 bytes (255.556641 MiB)
    Magic
    Tipo file                   RIFF (little-endian) data, AVI, 720 x 400, 25.00 fps, video: XviD,
                                audio: MPEG-1 Layer 3 (stereo, 48000 Hz)
    Info generiche
    Durata                      00:20:17 (1217.12 s)
    Contenitore                 AVI OpenDML
    L'AVI ha un indice?         Sì
    Totale tracce               2
    Traccia n. 0                video
    Traccia n. 1                audio
    ISFT                        VirtualDubMod 1.5.10.2 (build 2540/release)
    Junk                        VirtualDubMod build 2540/release
    Dati rilevanti
    Risoluzione                 720 x 400
    Larghezza                   multipla di 16
    Altezza                     multipla di 16
    DRF medio                   2.68759
    Deviazione standard         1.000792
    Media pesata dev. std.      0.606285
    Traccia video
    FourCC                      xvid/XVID
    Frame aspect ratio          9:5 = 1.8
    Pixel aspect ratio          1:1 = 1
    Display aspect ratio        9:5 = 1.8
    Framerate                   25 fps
    Totale frames               30,428
    Dimensione stream           247,009,634 bytes (235.566744 MiB)
    Bitrate                     1623.56799 kbps
    Qf                          0.225496
    Key frames                  328 (0; 288; 588; 888; 1188; ... 30357)
    Null frames                 0
    Min key int                 1
    Max key int                 300
    Avg key int                 92.768293
    Ritardo                     0 ms
    Traccia audio
    Audio tag                   0x55 (MP3)
    Canali                      2
    Chunks                      30,416
    Dimensione stream           19,473,792 bytes (18.571655 MiB)
    Tipo di bitstream (bs)      MPEG-1 Layer III
    Frames (bs)                 50,713
    Durata                      00:20:17 (1217.112 s)
    Chunk-aligned (bs)          Sì
    Bitrate (bs)                128 kbps CBR
    Freq. campionamento (bs)    48000 Hz
    Modo (bs)                   joint stereo
    Padding (bs)                No
    Emphasis (bs)               none
    Preload                     504 ms
    Max A/V diff                520 ms
    Ritardo                     0 ms
    Bitstream video
    Tipo di bitstream           MPEG-4 Part 2
    User data                   DivX503b1393
    User data                   XviD0073
    Packed bitstream            No
    QPel                        No
    GMC                         No
    Interlacciamento            No
    Aspect ratio                Square pixels
    Quant type                  H.263
    Drop/delay frames           0
    Frames corrotti             0
    I-VOPs                        328 (  1.078 %)
    P-VOPs                      10653 ( 35.011 %) #######
    B-VOPs                      19447 ( 63.912 %) #############
    S-VOPs                          0 (  0.000 %)
    N-VOPs                          0 (  0.000 %)
    Max B-VOPs consecutivi      2
        1 consec                1207 ( 11.688 %) ##
        2 consec                9120 ( 88.312 %) ##################
    Analisi DRF
    DRF nedio                   2.68759
    deviazione standard         1.000792
    max DRF                     4
    DRF=1                       3970 ( 13.047 %) ###
    DRF=2                       9566 ( 31.438 %) ######
    DRF=3                       8892 ( 29.223 %) ######
    DRF=4                       8000 ( 26.292 %) #####
    DRF>4                          0 (  0.000 %)
    I-VOPs DRF medio            1.17378
    I-VOPs deviazione std.      0.378921
    I-VOPs max DRF              2
    P-VOPs DRF medio            1.652774
    P-VOPs deviazione std.      0.476088
    P-VOPs max DRF              2
    B-VOPs DRF medio            3.279992
    B-VOPs deviazione std.      0.681441
    B-VOPs max DRF              4
    Conformità al profilo
    Profilo selezionato         MTK PAL 6000
    Risoluzione                 Ok
    Framerate                   Ok
    Min riempimento buffer      78%
    Rapporto creato da AVInaptic (18-12-2011) in data 16-03-2015 13:31:41
    *EDIT 2*
    The DRF Analysis of encoding 05.mpeg using xvid4psp:
    Info sul file
    Nome                        05_OK_xvid4psp.avi
    Data                        Sat, 14 Mar 2015 22:04:08 +0100
    Dimensione                  270,473,216 bytes (257.943359 MiB)
    Magic
    Tipo file                   RIFF (little-endian) data, AVI, 720 x 408, 25.00 fps, video: XviD,
    Info generiche
    Totale tracce               2
    Traccia n. 0                video
    Traccia n. 1                audio
    ISFT                        VirtualDubMod 1.5.10.3 | www.virtualdub-fr.org || (build
                                2550/release)
    Junk                        VirtualDubMod build 2550/release
    Dati rilevanti
    Risoluzione                 720 x 408
    Altezza                     multipla di 8
    DRF medio                   2.563757
    Deviazione standard         0.999824
    Media pesata dev. std.      0.604714
    Traccia video
    FourCC                      xvid/XVID
    Frame aspect ratio          30:17 = 1.764706 (~16:9)
    Display aspect ratio        30:17 = 1.764706 (~16:9)
    Framerate                   25 fps
    Dimensione stream           249,511,624 bytes (237.952827 MiB)
    Bitrate                     1640.013304 kbps
    Qf                          0.223313
    Key frames                  327 (0; 288; 588; 888; 1188; ... 30357)
    Null frames                 0
    Min key int                 1
    Max key int                 300
    Avg key int                 93.051988
    Ritardo                     0 ms
    Traccia audio
    Canali                      2
    Chunks                      30,416
    Encoder (bs)                LAME3.99r
    Frames (bs)                 50,713
    Modo (bs)                   stereo
    Padding (bs)                No
    Emphasis (bs)               none
    Preload                     504 ms
    Max A/V diff                520 ms
    Ritardo                     0 ms
    Bitstream video
    User data                   XviD0050
    Packed bitstream            No
    QPel                        No
    GMC                         No
    Interlacciamento            No
    Quant type                  H.263
    Drop/delay frames           0
    Frames corrotti             0
    I-VOPs                        327 (  1.075 %)
    P-VOPs                      15237 ( 50.076 %) ##########
    B-VOPs                      14864 ( 48.850 %) ##########
    S-VOPs                          0 (  0.000 %)
    N-VOPs                          0 (  0.000 %)
    Max B-VOPs consecutivi      1
    Analisi DRF
    DRF nedio                   2.563757
    deviazione standard         0.999824
    max DRF                     4
    DRF=1                        4523 ( 14.865 %) ###
    DRF=2                       11172 ( 36.716 %) #######
    DRF=3                        7789 ( 25.598 %) #####
    DRF=4                        6944 ( 22.821 %) #####
    DRF>4                           0 (  0.000 %)
    I-VOPs DRF medio            1.250765
    I-VOPs deviazione std.      0.480307
    I-VOPs max DRF              3
    P-VOPs DRF medio            1.800223
    P-VOPs deviazione std.      0.566499
    P-VOPs max DRF              3
    B-VOPs DRF medio            3.375336
    B-VOPs deviazione std.      0.646625
    B-VOPs max DRF              4
    Risoluzione                 Ok
    Framerate                   Ok
    Min riempimento buffer      79%
    Rapporto creato da AVInaptic (18-12-2011) in data 16-03-2015 13:35:00
  17. Why do you so concerned that one file turns out a little larger than the others? Xvid simply misses the requested bitrate on occasion. If it bothers you so much request a lower bitrate so when it comes out oversized it matches what you really want.
  18. Originally Posted by jagabo View Post
    Lol .. just to better understand Infact the strange situation it's all other episodes (01..02..03.. 10 in mpeg2) it's all ok... the desidered bitrate and filesize i choose was respected
    Only whit this 05.mpeg i have this little problems... i have tryed to encoding two times whit xvid4psp and one time whit GK and in all cases i obtain a filesize about 14/15MB larger than desired and i don't understand becouse
    I'm just trying to figure out if it's an error in the encoding phase or if it's a my error on encoder setting
    I want to learn and explore every secret of xvid encoding
    *EDIT*
    I have also tested all this two file on my Home TV and otherwise i'm really satisfed about the result.....
    I did not do a thing here on board.... I have not thanked you for the valuable advice given to me.... thanks.
  19. That would have been my next suggestion as well - if this is the only one ever to have had the problem, just lower the requested output size by the necessary amount. Also, I don't (didn't, when I used to use XviD) allow for quant 1. Two was my minimum as quant 1 is used only to bloat the file size because people sometimes complained about undersized encodes and the developers got tired of it.
  20. Originally Posted by manono View Post
    mmmmmmmmmmmm...... i thinks i can try...... for example if the desidered bitrate calculated for 240B it's 1526. After encoding it's complete the final used encoding it's 1624 (255MB indesidered filesize) i can try to set the bitrate to 1624-1526 = 98.. i can set the bitrate to 1428.....
  21. OH My GOD.... Oh my GOD!!
    It's this two or three hours... i try... re-try..... and re-tryed again and again using GK for encoding 05.mpeg to XVID whit exact filesize to 240MB!
    It's impossible!! The best result i have obtained it's this:
    General
    Complete name               : D:\Wilfred\05_OK_GK.avi
    Format                      : AVI
    File size                   : 235 MiB
    Duration                    : 20mn 17s
    Overall bit rate            : 1 621 Kbps
    Video
    Codec ID                    : XVID
    Duration                    : 20mn 17s
    Bit rate                    : 1 483 Kbps
    Width                       : 720 pixels
    Height                      : 400 pixels
    Color space                 : YUV
    Bit depth                   : 8 bits
    Bits/(Pixel*Frame)          : 0.206
    Stream size                 : 215 MiB (91%)
    Audio
    Format                      : MPEG Audio
    Mode                        : Joint stereo
    Codec ID                    : 55
    Codec ID/Hint               : MP3
    Duration                    : 20mn 17s
    Bit rate                    : 128 Kbps
    Stream size                 : 18.6 MiB (8%)
    I can't understand........ on setting GK i have all configured to obtain and use a bitrate about 1431 for obtain a videofile aroud 221MB... after that i tryed to MUXING the mp3 about 19MB and total size it's 240MB!! But what's i wrong !?!?!? I can't understand........ the encoding using a different bitrate i choose (bigger) and i obtain a smallest video size Lol... i can't figure because.... very strange situation!
  22. I don't understand your obsession for getting them all the same size. By doing that they're not even of equal quality because different videos compress differently. If it were I, I'd make them all for quant 3 and some will be larger, some smaller in size, but all will have the same quality. The encoding will finish much faster as well.
  23. Originally Posted by manono View Post
    I repeat.. it's not an obsession but i need to understand what's appened during the compression of this stupid episodes and because my setting it's not respected
    About quantization... i have make all file whit default xvid setting or default profile using on xvid4psp
    It's the BVOP Value ??
    On GK i can choose manually i thinks right ? But on xvid4psp i have choose a profile of "Avi Hardware HD" -> 2P Xvid Extreme -> and i have change the bitrate to obtain the estimate filesize......... i need to watch how i can change the quant....
    *EDIT*
    I have also found some information..... like K-Lite Codec Pack on my Windows 7 i have installed a version 1.4.0 developer of xvid codec.......... at this point i thinks xvid4psp using a standalone xvid codec (i thinks using xvidencraw.exe) and not the xvid installed on system but GK using it.
    At this point i thinks the bitrate calculator on GK i thinks it's not accurated because it's developed whit a "old" version of xvid codec and it's possibly i whit a newest version i can obtain a smallest or better compression.......
  24. I haven't used Xvid4PSP in a long time and the version I have installed is old. But after selecting an Xvid preset go to the encoder settings dialog and look for Encoding Mode. Set it to Constant Quality. You should then see a Quality (Q) settings. Try 3.0. That's pretty much transparent at normal playback speed but if you look at enlarged still frames you'll see some block artifacts. Going down to 2 will get rid of those block artifacts but the file size will increase substantially. Going to higher values will lower the quality and give smaller file sizes. Note that Xvid does not obey the profile/level limitations when working in target quantizer mode. So bitrates might turn out too high for some old devices, etc.
  25. Originally Posted by jagabo View Post
    Lol....... i'm again so much confusion in my head
    I have re-try to use xvid4psp whit same profile i obtain the first 15MB bigger file. This time i have try 240 - 15 and set the filesize to 225MB and i have obtain (after about 40minutes) this:
    Directly from LOG file:
    Tempo totale della codifica: 44 min 55 sec
    La dimensione del file è: 224.42 mb
    Yeah....... now the filesize it's been respected... but if i raise it to 240MB i thinks i reobtain a 255MB file
  26. Face it, Xvid sometimes misses the requested bitrate. I don't think anybody knows why, including the developers.
  27. AND FINALLY... LOOK AT HERE:
    I'M WINNER VERSUS PC!!
    General
    Complete name               : D:\Wilfred\05\05_OK.avi
    Format                      : AVI
    File size                   : 241 MiB
    Duration                    : 20mn 17s
    Overall bit rate            : 1 658 Kbps
    Video
    Codec ID                    : XVID
    Duration                    : 20mn 17s
    Bit rate                    : 1 521 Kbps
    Width                       : 720 pixels
    Height                      : 408 pixels
    Color space                 : YUV
    Bit depth                   : 8 bits
    Bits/(Pixel*Frame)          : 0.207
    Stream size                 : 221 MiB (92%)
    Audio
    Format                      : MPEG Audio
    Mode                        : Joint stereo
    Codec ID                    : 55
    Codec ID/Hint               : MP3
    Duration                    : 20mn 17s
    Bit rate                    : 128 Kbps
    After re-encode.... try... and re-try again.. and again i finally obtain what i want!!
    I have also using Gordian Knot whit 2 encoding pass using this setting:
    [Gordian Knot Settings]
    Name= 1
    Duration=1217
    BitrateConst=0
    Bitrate=1477
    TotalSize=1949696
    Audio1CalcSize=0
    Audio1Index=-1
    Audio1Size=152167
    Audio2CalcSize=0
    Audio2Index=-1
    Audio2Size=0
    FilesSize=0
    RGInputRes=0
    InputWidth=720
    InputHeight=576
    RGInputAspect=1
    InputAspect=1,36752136752137
    InputPixelAspect=1,09401709401709
    AspectMode=PAL
    RGCrop=1
    CropAspect=1,80616029672633
    CropTop=76
    CropBottom=76
    CropLeft=12
    CropRight=8
    WModul=4
    HModul=4
    TrackBar=45
    FPS=1
    Frames=30428
    Default=0
    InterleaveMode=disabilitato
    InterleaveMode2=disabilitato
    InterleaveDist=1
    DivXMode=0
    CalculateAVIOverhead=0
    D2VFile=D:\Wilfred\05\05_OK.d2v
    StatsFile=
    EncFrameServerFile=D:\Wilfred\05\05_OK.avs
    EncFrameServerCreditsFile=
    EncAVIOutputFile=D:\Wilfred\05\05_OK.avi
    EncStatsFile=
    EncECFFile=
    EncLogFile=D:\Wilfred\05\05_OK.log
    EncAudio1File=D:\Wilfred\05\05_OK T01 2_0ch 256Kbps DELAY 24ms.mp3
    EncAudio2File=
    CreditsStart=0
    CompTest=0
    CompTest4=0
    I have exported the profile.......... but very strange......... inside the programs the configuration it's completely different:
    I don't know because this appened (it's a graphical bug ??? )........ but i thinks i have found the correct way to configure them correctly:
    - I need the first time to put a value in bitrate...... an look the MB value....
    - After that change a little the value of MB whit up/down arrow...
    - Finally, before to start the encoding, goes to preview and click on Save&Encoding and control if the desider filesize and bitrate it's been respected!
    In this case the expended filesize it's reported to 224MB for only video track.. but after the two pass i obtain a perfectly 221MB (also if obtain a 224MB it's right otherwise) and 221+19 of mp3 it's 240MB!!
    I continue to not understand because only this 05.mpeg have reported and create all this trouble but this time...
    I WIN THE CAUSE versus my Pc
    And i'm not happy....... but SATISFIED like a GOD
