I have a .avi movie file that when i try to play it with potplayer it doesn't output any audio. If i play the file with other movie players it has audio. Any ides why potplayer play the movie with no audio? I don't have problems with other movie files that i played with potplayer but only with this one, and i guess the problem is with potplayer because other players are playing the movie with audio.
What is the audio in the avi? Identify with mediainfo or mediainfoxp.
edit: And did you install the "additional codec" when you installed potplayer? It's the last step in the installation.Last edited by Baldrick; 13th Mar 2015 at 05:12.
This is the information about the file generated with mediainfo:
Code:Complete name : E:\Movies\xxxxx.avi Format : AVI Format/Info : Audio Video Interleave File size : 1.33 GiB Duration : 3h 19mn Overall bit rate : 954 Kbps Writing application : VirtualDubMod 1.5.10.1 (build 2424/release) Writing library : VirtualDubMod build 2424/release Video ID : 0 Format : MPEG-4 Visual Format profile : Advanced Simple@L5 Format settings, BVOP : 2 Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Codec ID : XVID Codec ID/Hint : XviD Duration : 3h 19mn Bit rate : 752 Kbps Width : 544 pixels Height : 320 pixels Display aspect ratio : 1.700 Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.173 Stream size : 1.05 GiB (79%) Writing library : XviD 1.0.2 (UTC 2004-08-29) Audio ID : 1 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 2000 Duration : 3h 19mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 274 MiB (20%) Alignment : Split accross interleaves Interleave, duration : 40 ms (1.00 video frame) Interleave, preload duration : 500 ms
Potplayer has not built in codecs/splitters for all video so you must install them. If you don't want that use vlc media player.
@ alek8976: it really helps when you give all info you can (what OS+ x32/x64, what version of PotPlayer - stable/beta, x32/x64 and portable/installed), when explaining your problem. So people don't have to drag it from you and discover, after you suddenly drop on them it's a portable version, that they wasted their time, 'cos the solution might be different.
First you can check in PotPlayer what container/codecs the file is by right-click and choose Playback/System Info (or just CTRL+F1). Yes, it uses MediaInfo internally.
You can play with and see if any internal codec can decode the audio here: Preferences - Filter Control - Audio Decoder - Built-in Codec (S/PDIF, HDMI) settings. Go to AC3 and toggle/try all decoders. If there's nothing to toggle, you can download the codecs from here:
x32: http://get.daum.net/PotPlayer/Codec/OpenCodecSetup.exe
x64: http://get.daum.net/PotPlayer/Codec/OpenCodecSetup64.exe
Then unpack them and put into Module folder. FFmpegMininum.dll should go to FFmpeg folder together with FFmpeg.dll. I don't use portable version of PotPlayer, so I don't know, if it's gonna recognise them without using exe installer.
If still not working you can use somebody's portable repack from here (or just copy whole Module folder to yours):
http://vokol.deviantart.com/art/PotPlayer-Mini-Portable-428187430
It contains both x32 and x64 versions and all additional internal codecs. I don't know how portable it is and how safe, but my antivirus didn't give me any warning. -
It turns out that i didn't have the open codec in my Module folder. I extracted OpenCodecUnity.dll and put it there and now the movie has audio.
Thanks!
