  1. Hello Team & Experts.
    I am using Reply screen capture software.
    now i want install another software WM capture.
    both are similar in all things feature and all.
    can it effect on each other setting.
    Can i use simultaneously both software.
    I have different profile for recording. setting i like than i just have to select one area of recording.
    after closing software again run software than also i get my old selected region setting.
    where in other software it not allow.
    quality and output size in both are good.
    They shouldn't effect each capture settings. But I doubt you can capture with both simultaneously . Just try and report back. Try the trial!
  3. reason is that i want know..
    bcz i recording video so i have set screen already. if any problem arise than it cost me lots. i have view limits.
    both product are made by same company.
    I doubt you will find anyone that has tested both at same time....
  5. contacted replay they said it not going create problem. they are also not sure..
  6. Member WazaKrash's Avatar
    Jan 2015
    in Europe
    Personally I don't know, but we can see tutorial videos where people use a screen recorder for showing how to use other screen record software so maybe there is a special trick but you have to search it.
    perhaps, a webcam screen recorder software can record a screen recorder? should be tested by yourself to find out.
  7. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Record both using Mirillis Action. After finished, crop. Easy way.
    Yes. Mirillis Action record any screen on desktop.
    Claudio
