I need to convert this 3 file on a XVID (i have the same problems whit all 3 conversion)... i choose to use Xvid4PSP.
I have installed this on my Windows 7 X64:
XviD4PSP_5.10.346.0_(2015-02-12)_rc34.1.exe
After that i have load one of my three file... i can post a mediainfo of first for example:
If i play this mpeg file using Media Player Classic... or VLC the audio it's perfectly in sync..... i have try to load on Xvid4PSP... cut some parts at beginning at the end, apply trim.... and try to preview:Code:General Complete name : D:\07.mpg Format : MPEG-PS File size : 1.41 GiB Duration : 20mn 41s Overall bit rate mode : Variable Overall bit rate : 9 727 Kbps Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Default Format settings, GOP : Variable Format settings, picture st : Frame Duration : 20mn 41s Bit rate mode : Variable Bit rate : 9 300 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate : 25.000 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.897 Time code of first frame : 00:00:03:21 Time code source : Group of pictures header GOP, Open/Closed : Open Stream size : 1.34 GiB (95%) Color primaries : BT.601 PAL Transfer characteristics : BT.470 System B, BT.470 System G Matrix coefficients : BT.601 Audio ID : 189 (0xBD)-128 (0x80) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Muxing mode : DVD-Video Duration : 20mn 41s Bit rate mode : Constant Bit rate : 256 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -32ms Stream size : 37.9 MiB (3%) Menu
The first 4 or 5 minutes it's all ok.. but after that the audio begin to played completely out sync!
I have also tryed to complete a conversion and for example i obtain this:
Apparentry to audio and video tracks have same duration... but when i play this avi on MPC or VLC i have the same problems whit out of sync have about 40 minutes ago on preview.Code:General Complete name : D:\07.avi Format : AVI Format/Info : Audio Video Interleave File size : 200 MiB Duration : 20mn 40s Overall bit rate : 1 351 Kbps Writing application : VirtualDubMod 1.5.10.3 | www.virtualdub-fr.org || (build 2550/release) Writing library : VirtualDubMod build 2550/release Video ID : 0 Format : MPEG-4 Visual Format profile : Advanced Simple@L5 Format settings, BVOP : 1 Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Codec ID : DX50 Codec ID/Hint : DivX 5 Duration : 20mn 40s Bit rate : 1 213 Kbps Width : 1 024 pixels Height : 576 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.082 Stream size : 179 MiB (90%) Writing library : XviD 1.2.1 (UTC 2008-12-04) Audio ID : 1 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Codec ID : 55 Codec ID/Hint : MP3 Duration : 20mn 40s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 18.9 MiB (9%) Alignment : Aligned on interleaves Interleave, duration : 40 ms (1.00 video frame) Interleave, preload duratio : 504 ms Writing library : LAME3.99r Encoding settings : -m s -V 4 -q 0 -lowpass 17 -b 128
What's my problems ?? It's the source ?? How i can resolve and convert this file ??
I have also tryed to load this file using the Copy profile and i obtain the same problems.......... what's the problems ?
It's this latest version bugged or some incompatible whit windows 7 x64 ?
Have you tried convert without cutting? Maybe it's causing the problems.
Yeah... i have found the solution on same forum yesterday by Google
I can try to explain:
For cutting the biggest mpeg2 i have used AviDemux... but i have split this file not in keyframe... at this point i thinks i have obtain 3 parts like corrupted mpeg
When i play this parts on player the sync it's ok.. but when i try to encode or load on some encoders and play for it i obtain the sync problems i have ask about here.
After google i have found a solution....... i have tryed to slit the source mpeg2 whit VideoReDo and after that all my problems it's disappers:
The answer it's when VideoReDo save the splitted mpeg not in keyframe they can apply a litte re-encode to output mpeg2 and after that i can use this splitted mpeg2 on encoding software whitout any sync problems.
