Results 1 to 12 of 12
    Dec 2002
    Apologies for my nieveity but I am puzzled why one MKV file will play on my smart TV, and another MKV file will not, im assumig one file has different characteristics to the other. the MKV files that wont play are files created by MAKE MKV from a DVD.
    What program can I use to look at the build up of the MKV file and compare it to the MKV file that plays fine.
    My Blu-ray player plays all the files faultlessly.
    Thanks for any advice
  2. Member bat999's Avatar
    Feb 2008
    Hi
    MediaInfo should do it.
    Compare the audio and video codecs used for the different types of files.
  3. I'm a Super Moderator johns0's Avatar
    canada
    Head stripping and also having 5.1 profile settings will cause most issues with mkv especially ones d/l from the net.
    Dec 2002
    the issues are with an original commercial DVD I purchased last week, no 5.1 soundtrack basic documentary film that I converted to MKV using MAKEMKV.
    Thanks for the advice chaps, I wil try Mediainfo
    Dec 2002
    I have veiwed the file details in MEDIAINFO and this is what it has told me....
Name:	Dibnah MKV details.jpg
    and here is the playback capabilities of my Bravia TV
    http://pdf.crse.com/manuals/14HE394111/EN/codeclist.html#section03
    I somewhat confused when it comes to comparing Video file types, what do you guys experts reckon should this MKV file play on my TV and if not WHY ?
    , THANKS for your assistance
    May 2014
    Memphis TN, US
    No, MediaInfo told you a lot more than that..........
    We'd like to see the rest of the data. Use "Text" view from the top menu bar, copy the text of the entire Text View, and paste it in here. Save yourself the trouble of making pics when Text is more easily available.
    Is there some reason why you have MPEG2 in a Matroska container?
    - My sister Ann's brother
    Dec 2002
    ok will do, thanks for sticking with me, As I say above I just load the file into MakeMKV and let it work......
    Dec 2002
    Heres the full info....
    eneral
    Unique ID : 321115420562484260612749511548656599220 (0xF1949495868AD44F2BA9B313464AC0B4)
    Complete name : Z:\Videos\Fred Dibnah Volume One\title00.mkv
    Format : Matroska
    Format version : Version 2
    File size : 1.05 GiB
    Duration : 29mn 2s
    Overall bit rate : 5 197 Kbps
    Encoded date : UTC 2015-03-09 18:23:21
    Writing application : MakeMKV v1.9.1 win(x86-release)
    Writing library : libmakemkv v1.9.1 (1.3.0/1.4.1) win(x86-release)
    Video
    Format : MPEG Video
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=12
    Format settings, picture structure : Frame
    Codec ID : V_MPEG2
    Codec ID/Info : MPEG 1 or 2 Video
    Duration : 29mn 2s
    Bit rate : 4 902 Kbps
    Maximum bit rate : 5 000 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.473
    Time code of first frame : 00:00:00:00
    Time code source : Group of pictures header
    GOP, Open/Closed : Closed
    Stream size : 1 018 MiB (94%)
    Language : English
    Default : No
    Forced : No
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : A_AC3
    Duration : 29mn 2s
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 39.9 MiB (4%)
    Title : Stereo
    Language : English
    Default : Yes
    Forced : No
    May 2014
    Memphis TN, US
    Thanks for the details.
    Likely your smart TV isn't as smart as your BluRay player and won't play MPEG2 in an mkv container, which is not a hot idea to begin with. What's wrong with playing the DVD?
    All you need now is a MediaInfo report on one of the mkv's that plays OK. Chances are they aren't encoded as MPEG. But you never know.... Don't know which Smart TV you have, so can't say..
  10. If your DVD is copy protected you can rip it with AnyDVD in the backround or DVDFab HD Decrypter.
    And then use VOB2MPG (or AviDemux, MPEGStreamclip) to make a .mpg file. Perhaps your TV like that better.
    Dec 2002
    MPeg working perfectly THANKS Chaps!!. whats best for merging Mpeg files by the way!!
    May 2014
    Memphis TN, US
    You should merge before encoding. Otherwise, TMPGenc Smart Renderer. Handles DVD, BluRay, etc., has a timeline feature if you need it. Trial version available. If you already own a TMPGEnc product, you get a discount. There are free editor/joiners, but most are severely limited and won't smart-render with frame-specific editing.
