I would like to cut out and save an audio section from a mkv file in ffmpeg. The audio track is AAC. Would saving the output as AAC decrease the output quality since it's a lossy format?
I tried this command, but it didn't work:
Here is the error description that cmd gave me:Code:ffmpeg -i input.mkv -vn -c:a -ss 00:01:42:11 -t 00:02:02:19 output.aac
[NULL @ 0000000005629940] Unable to find a suitable output format for '00:01:42:11'
00:01:42:11: Invalid argument
Results 1 to 9 of 9
Ah, I forgot to add that.
cmd gave me this now:
Invalid duration specification for ss: 00:01:42:11 -
This gives me a 01:57 minute long audio clip. I was trying to get a 20 second clip (or 00:00:20:007, to be specific).
-t is duration, not end time
-t 00:00:20.007
If you still can't get it working, you can demux the audio and use mp3directcut (it works on AAC as well) -
I tried that before as well, but it didn't work then. Looks like I used a comma instead of a dot for the microseconds part.
I have gotten a higher quality audio source now, so I'll just have to redo this with an AC3 track.
Thanks! -
This sometimes works better for duration seeking:
Code:ffmpeg -ss 00:01:42.011 -i input.mkv -to 00:00:20.007 -vn -c:a copy output.aac
PB
s.ms
