hi all
how can i find the f4m link in ooyala vidoes ?
	If you found fragments, the f4m url would be the same except ending in _1.f4m
 OO.Player.create('ooyalaplayer', '<code here>'
 code at 'code here' is the embed code.
 embed code_1.f4m
 But if it has drm, this won't help you at all. You'll have to say the name of the website and provide the embed code.
	Hi poenens,
 thanks for your reply. it is drm protected.. can u give me some guidelines of how to fine the url even though its drm protected ? do i need any special software.. i have send u a PM with the page and embedded code.
	I have got the embed code and the fragment is ending with video_2200_1280Seg1-Frag3
 so which part should i replace to f4m ?
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
