    Mar 2015
    edit
    hi, so i have two lossless demo trailers 1080p one DTSHDMA and DolbyTrue HD ( both AVCHD original files )and burned to seperate DVD-RW for test using TSMuxer and IMGburn to start with and skipping all the way ( audio and video) in Panasonic BD85 but will play fine in the laptop , any ideas....... btw this is my first post here . : )
    Maybe crappy dvdrw media. Try another brand or maybe dvdr.
    And post the avchd details. Use mediainfo, open m2ts and view->text and post the details.
    Mar 2015
    edit
    baldrick, youll be familiar with these.
    General
    Complete name : C:\Users\xxxx\Desktop\hd_dts_animated_logo_lossles s-DWEU.m2ts
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 93.2 MiB
    Duration : 22s 50ms
    Overall bit rate : 35.5 Mbps
    Maximum Overall bit rate : 48.0 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : 27
    Duration : 21s 355ms
    Bit rate mode : Variable
    Maximum bit rate : 37.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Audio
    Menu ID : 1 (0x1)
    Format : DTS
    Format/Info : Digital Theater Systems
    Format profile : MA / Core
    Mode : 16
    Format settings, Endianness : Big
    Muxing mode : Stream extension
    Codec ID : 134
    Duration : 21s 344ms
    Bit rate : Unknown / 1 509 Kbps
    Channel(s) : 8 channels / 6 channels
    Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Compression mode : Lossless / Lossy
    and.....
    General
    Complete name : C:\Users\xxxx\Desktop\hd_dolby_catalyst_lossless-DWEU.m2ts
    Format : BDAV
    File size : 13.0 MiB
    Duration : 13s 590ms
    Overall bit rate : 8 008 Kbps
    Video
    Menu ID : 1 (0x1)
    Format : VC-1
    Format profile : Advanced@L3
    Codec ID : 234
    Duration : 12s 54ms
    Bit rate : 7 234 Kbps
    Color space : YUV
    Bit depth : 8 bits
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.146
    Stream size : 10.4 MiB (80%)
    Audio
    Menu ID : 1 (0x1)
    Format : TrueHD / AC-3
    Codec ID : 131
    Duration : 13s 13ms
    Bit rate mode : Variable / Constant
    Bit rate : 448 Kbps
    Maximum bit rate : 6 336 Kbps
    Bit depth : 16 bits
    Stream size : 712 KiB (5%)
  4. You need to use BD media (BD25/50) for the 1st one, the bitrates are too high for DVD media.
    Maxrate for DVD5/9 media should be kept under 15Mb/s - the physical transfer speed isn't high enough
    Panasonic players tend to be very picky on what they will play
    Mar 2015
    edit
    The battle so far, DTSHDMA trailer ..BRRebuilder Full Backup mode output BD5 X265LAVF frameserve ( log indicates indeed 15mb video limit ) this way audio does not convert to AC3 ( keeping original audio ) , done, stop , start TSMuxer load M2TS file from previous operation output as AVCHD disk , done, stop , start IMGBurn and write files and folders to disc in the usual way, done .
    BRRebuilder will complete the first task by itself but Panasonic reports " unsupported ".
    Dolby TrueHD trailer HDaudio not loading in BRRebuilder . Stop.
