OK I have done hundreds of conversions to svcd of mpg and avi files fin e no issues!!
BUT I have recently the need to convert 4 *.mov files I have the plugin installed
tmpgenc loads the files no problem I choose the settings I want and start the conversion the software start the conversion gets about 11 frames in then hangs. I tried increasing the priority still no joy same problem.
So Ok I think I'll try converting it first so I have tried mov2avi but I am not sure exactly how to express the codecs and things so then I tried some a quickeditor and smartvid all to no avail
can anyone who has some experience with this please help me out?
On a similar note..can .mov files simply be converted by Nero like Nero does with other formats to MPEG? Save a step and all that.
I tried nero but got unsupported format now wether that is my files or all .mov files I am unclear
Also nero is so painfully slow !! and from what I read not as high quality?
I read else where there is a need to convert from one format of .mov to another before converting to avi or mpeg? to be honest I am getting really annoyed with it!! -
The best piece of software I found that gives good quality and easy to encode .mov to .mpg/.avi is EO Video.
I have been using EO Video to convert my movie trailer collection with no problems at all.
You'll find a link to EO Video at http://www.vcdhelp.com/vcdtools.htm -
Try this Quicktime plugin:
http://www.geocities.com/SiliconValley/4942/svcd.html<br /> <br /> Set it to "1" in ...ntal settings. -
As I said I have tried that !!
I have just tried quicktime pro that converts to AVI nicely but I will try eo video next
help -No sound when converting .mov files
By bloke666 in forum ffmpegX general discussionReplies: 0Last Post: 11th Dec 2011, 12:48 -
Converting or Joining MOV files
By theWallflower in forum Video ConversionReplies: 3Last Post: 8th Apr 2010, 08:00 -
Batch Converting MOV Files
By thomasj in forum LinuxReplies: 3Last Post: 25th Dec 2009, 15:50 -
converting .mov files to something I can use
By weazel_k in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2007, 17:46 -
Converting layered WMV files to MOV
By whoisquilty in forum MacReplies: 3Last Post: 19th May 2007, 14:18
