Hello,
can somebody tell me please, for which audio format the -channel_layout parameter of FFMPEG is supported or how to find out ?
At this webpage :
http://en.wikibooks.org/wiki/FFMPEG_An_Intermediate_Guide/AVCodecContext_AVOptions#-channel_layout
it says :
-channel_layout
FFMPEG: Encode, Decode, Audio
Full Name:
Variables: Integer 64bit
Codecs: all
Web sites:
Description:
why do you think many audio converters don't have channel layout as parameter parameter ?
Channel_layout is used by some filters but not by any codecs or formats (muxer/demuxers). Go to the filters documentation and search for all the filters that implement it.
It seems to be used when i encode an AAC audio file.
Check out the following :
Code:c:\1>ffmpeg -i natgeo.mp4 -vn -strict -2 -c:a aac -channel_layout SR a.aac ffmpeg version N-68625-g1728659 Copyright (c) 2000-2014 the FFmpeg developers built on Dec 19 2014 22:02:36 with gcc 4.9.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab le-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca -- enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-lib modplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrw b --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinge r --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --en able-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable- libx265 --enable-libxavs --enable-libxvid --enable-decklink --enable-zlib libavutil 54. 15.100 / 54. 15.100 libavcodec 56. 16.100 / 56. 16.100 libavformat 56. 16.101 / 56. 16.101 libavdevice 56. 3.100 / 56. 3.100 libavfilter 5. 4.100 / 5. 4.100 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 3.100 / 53. 3.100 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'natgeo.mp4': Metadata: major_brand : isom minor_version : 1 compatible_brands: isom creation_time : 2012-07-09 11:58:52 Duration: 00:01:00.29, start: 0.000000, bitrate: 1932 kb/s Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709/ unknown/unknown), 720x406, 1800 kb/s, 25 fps, 25 tbr, 25k tbn, 50 tbc (default) Metadata: creation_time : 2012-07-08 08:37:43 handler_name : Video Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, flt p, 128 kb/s (default) Metadata: creation_time : 2012-07-08 08:37:49 handler_name : GPAC ISO Audio Handler File 'a.aac' already exists. Overwrite ? [y/N] y Output #0, adts, to 'a.aac': Metadata: major_brand : isom minor_version : 1 compatible_brands: isom encoder : Lavf56.16.101 Stream #0:0(eng): Audio: aac, 48000 Hz, 1 channels (SR), fltp, 128 kb/s (def ault) Metadata: creation_time : 2012-07-08 08:37:49 handler_name : GPAC ISO Audio Handler encoder : Lavc56.16.100 aac Stream mapping: Stream #0:1 -> #0:0 (aac (native) -> aac (native)) Press [q] to stop, [?] for help size= 964kB time=00:01:00.28 bitrate= 131.0kbits/s video:0kB audio:944kB subtitle:0kB other streams:0kB global headers:0kB muxing o verhead: 2.046242% -
It's not documented at http://www.ffmpeg.org/ffmpeg-codecs.html#aac. Channel_layout is listed as a global codec option but without any possible values. If the docs are incomplete, I guess you'll have to search the source code.
Channel names:If the docs are incomplete, I guess you'll have to search the source code.
source: http://www.ffmpeg.org/doxygen/2.0/channel__layout_8c.html#a455b3328b02048db7255da22bea6de6dCode:{ [0] = { "FL", "front left" }, [1] = { "FR", "front right" }, [2] = { "FC", "front center" }, [3] = { "LFE", "low frequency" }, [4] = { "BL", "back left" }, [5] = { "BR", "back right" }, [6] = { "FLC", "front left-of-center" }, [7] = { "FRC", "front right-of-center" }, [8] = { "BC", "back center" }, [9] = { "SL", "side left" }, [10] = { "SR", "side right" }, [11] = { "TC", "top center" }, [12] = { "TFL", "top front left" }, [13] = { "TFC", "top front center" }, [14] = { "TFR", "top front right" }, [15] = { "TBL", "top back left" }, [16] = { "TBC", "top back center" }, [17] = { "TBR", "top back right" }, [29] = { "DL", "downmix left" }, [30] = { "DR", "downmix right" }, [31] = { "WL", "wide left" }, [32] = { "WR", "wide right" }, [33] = { "SDL", "surround direct left" }, [34] = { "SDR", "surround direct right" }, [35] = { "LFE2", "low frequency 2" }, };
Channel layout names:
source: http://www.ffmpeg.org/doxygen/2.0/channel__layout_8c.html#a70c71aa3e5d98eefb119900642b2cddbCode:static const struct { const char *name; int nb_channels; uint64_t layout; } channel_layout_map[] = { { "mono", 1, AV_CH_LAYOUT_MONO }, { "stereo", 2, AV_CH_LAYOUT_STEREO }, { "2.1", 3, AV_CH_LAYOUT_2POINT1 }, { "3.0", 3, AV_CH_LAYOUT_SURROUND }, { "3.0(back)", 3, AV_CH_LAYOUT_2_1 }, { "4.0", 4, AV_CH_LAYOUT_4POINT0 }, { "quad", 4, AV_CH_LAYOUT_QUAD }, { "quad(side)", 4, AV_CH_LAYOUT_2_2 }, { "3.1", 4, AV_CH_LAYOUT_3POINT1 }, { "5.0", 5, AV_CH_LAYOUT_5POINT0_BACK }, { "5.0(side)", 5, AV_CH_LAYOUT_5POINT0 }, { "4.1", 5, AV_CH_LAYOUT_4POINT1 }, { "5.1", 6, AV_CH_LAYOUT_5POINT1_BACK }, { "5.1(side)", 6, AV_CH_LAYOUT_5POINT1 }, { "6.0", 6, AV_CH_LAYOUT_6POINT0 }, { "6.0(front)", 6, AV_CH_LAYOUT_6POINT0_FRONT }, { "hexagonal", 6, AV_CH_LAYOUT_HEXAGONAL }, { "6.1", 7, AV_CH_LAYOUT_6POINT1 }, { "6.1", 7, AV_CH_LAYOUT_6POINT1_BACK }, { "6.1(front)", 7, AV_CH_LAYOUT_6POINT1_FRONT }, { "7.0", 7, AV_CH_LAYOUT_7POINT0 }, { "7.0(front)", 7, AV_CH_LAYOUT_7POINT0_FRONT }, { "7.1", 8, AV_CH_LAYOUT_7POINT1 }, { "7.1(wide)", 8, AV_CH_LAYOUT_7POINT1_WIDE_BACK }, { "7.1(wide-side)", 8, AV_CH_LAYOUT_7POINT1_WIDE }, { "octagonal", 8, AV_CH_LAYOUT_OCTAGONAL }, { "downmix", 2, AV_CH_LAYOUT_STEREO_DOWNMIX, }, };
Would be just too confusing, since the user would need to know the channel layout of the input and output formats.why do you think many audio converters don't have channel layout as parameter parameter ?
Some tools allow remixing (changing the channel composition), which basically allows you to specific the channel layout you want for the output, but still requires you to know the channel layout of the input and output formats, which can get messy for when you use 6 or more channels,...users currently on my ignore list: deadrats, Stears555, marcorocchini
