HCEnc problem: video is not YV12,YUY2,YV16 ot YV24 color space
AVS script of input file:
MediaInfo of input video:Code:Video = AVISource("D:\Filmovi\DTS x264-SilverTorrentHD\aa.avi") Video = Video.ConvertToYV12() Video = Video.AddBorders(0,94,0,94) Video = Video.Spline16Resize(720,576)
Code:General Complete name : D:\Filmovi\DTS x264-SilverTorrentHD\aa.avi Format : AVI Format/Info : Audio Video Interleave File size : 56.7 MiB Duration : 2mn 5s Overall bit rate : 3 803 Kbps Writing library : VirtualDub build 35491/release Video ID : 0 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 12 frames Codec ID : AVC1 Duration : 2mn 5s Bit rate : 3 798 Kbps Nominal bit rate : 4 123 Kbps Width : 1 280 pixels Height : 532 pixels Display aspect ratio : 2.40:1 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.233 Stream size : 56.6 MiB (100%) Writing library : x264 core 130 r2273 b3065e6 Encoding settings : cabac=1 / ref=12 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=4123 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=2:1.00
SOLUTION:
Code:Video = AVISource("D:\Filmovi\DTS x264-SilverTorrentHD\aa.avi") Video = Video.ConvertToYV12() Video = Video.AddBorders(0,94,0,94) Video = Video.Spline16Resize(720,576) return Video
Your problem is that you always assign the result to a clip variable named "Video", but you never let the content of this variable return out of the script. If you don't explicitly return anything, then AviSynth returns the implicit clip variable "last", which contains nothing in your case.
So, either add
Code:return Video
Code:AVISource("D:\Filmovi\DTS x264-SilverTorrentHD\aa.avi") ConvertToYV12() AddBorders(0,94,0,94) Spline16Resize(720,576)
