  1. Hey everyone,
    Im almost at the point of giving in on this, I have spend roughly 18+hrs on trying to get this sorted but with no luck, so this is my last resort.
    I have Multiple MP4 files that i am editing the audio track on, i have done 14 so far without issue, But this one is giving me nightmares,
    This is the file info according to FFMPEG,
    [STREAM]
    index=0
    codec_name=h264
    codec_long_name=H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
    profile=High
    codec_type=video
    codec_time_base=1001/60000
    codec_tag_string=avc1
    codec_tag=0x31637661
    width=1280
    height=720
    has_b_frames=1
    sample_aspect_ratio=1:1
    display_aspect_ratio=16:9
    pix_fmt=yuv420p
    level=40
    color_range=N/A
    color_space=unknown
    timecode=N/A
    id=N/A
    r_frame_rate=30000/1001
    avg_frame_rate=848910000/28331303
    time_base=1/90000
    start_pts=1890
    start_time=0.021000
    duration_ts=934932999
    duration=10388.144433
    bit_rate=4278652
    max_bit_rate=N/A
    bits_per_raw_sample=8
    nb_frames=311267
    nb_read_frames=N/A
    nb_read_packets=N/A
    DISPOSITION:default=1
    DISPOSITION:dub=0
    DISPOSITION:original=0
    DISPOSITION:comment=0
    DISPOSITION:lyrics=0
    DISPOSITION:karaoke=0
    DISPOSITION:forced=0
    DISPOSITION:hearing_impaired=0
    DISPOSITION:visual_impaired=0
    DISPOSITION:clean_effects=0
    DISPOSITION:attached_pic=0
    TAG:language=und
    TAG:handler_name=VideoHandler
    [/STREAM]
    [STREAM]
    index=1
    codec_name=aac
    codec_long_name=AAC (Advanced Audio Coding)
    profile=unknown
    codec_type=audio
    codec_time_base=1/48000
    codec_tag_string=mp4a
    codec_tag=0x6134706d
    sample_fmt=fltp
    sample_rate=48000
    channels=2
    channel_layout=stereo
    bits_per_sample=0
    id=N/A
    r_frame_rate=0/0
    avg_frame_rate=0/0
    time_base=1/48000
    start_pts=0
    start_time=0.000000
    duration_ts=498631680
    duration=10388.160000
    bit_rate=93450
    max_bit_rate=N/A
    bits_per_raw_sample=N/A
    nb_frames=486854
    nb_read_frames=N/A
    nb_read_packets=N/A
    DISPOSITION:dub=0
    TAG:language=und
    TAG:handler_name=SoundHandler
    [/STREAM]
    This is how i work with my files,
    Import Original MP4 into Sony Vegas > Edit audio as needed > render as mp4 with only AAC audio track > demux original MP4 > Demux edited MP4 > Mux edited AAC and original H264 into output MP4.
    That has worked flawlessly for hours of footage.
    With this file i have tried demuxing and muxing with the following programs,
    My MP4 Box GUI
    MediaCoder
    mp4muxer
    DGAVCindex
    However, the output file is always out of sync, Even if i demux the original MP4 and mux it.. it turns out exactly the same, its either in sync at the beginning of the video and out of sync at the end, or visa versa.
    I have completely re-encoded the file using mediacoder and the output is out of sync... which makes no sense,
    The original MP4 is Perfect, in terms of it plays fine, without any sync issues,
    One thing i have noticed however is that when i check the demuxed audio, it says it is 1:27:02 mins, but will play until the original length of 2:53:08, Another thing is that Sony Vegas reports the frame rate as 29.964 when everything else reports it as 29.970 (same as all the other videos i have edited)
    It feels as though i have tried everything i can find on google, but never had any luck,
    I am trying to keep the original unedited H264 stream, purely because of quality and its never touched.
    Any help would be fantastic,
    Chris.
  2. Probably VFR. The "off" frame rate in Vegas is a clue. When you demux from a container, you lose the timecodes which keep everything in sync
    What does mediainfo (view=>text) say ?
  3. Originally Posted by poisondeathray View Post
    Hi, thanks for the quick reply,
    Just checked what VFR is and i feel dumb for not knowing that, When muxing with mp4muxer, i have tried the variable frame rate check box with no discernible difference in the output,
    But this is the media info output.
    General
    Complete name               : C:\Sin.2001.720p.mp4
    Format                      : MPEG-4
    Format profile              : Base Media
    Codec ID                    : isom
    File size                   : 5.54 GiB
    Duration                    : 2h 53mn
    Overall bit rate mode       : Variable
    Overall bit rate            : 4 580 Kbps
    Tagged date                 : UTC 2015-03-06 01:52:34
    Writing application         : Lavf55.32.101 mp4creator 1.6.1d
    Video
    Format                      : AVC
    Format/Info                 : Advanced Video Codec
    Format profile              : High@L4.0
    Format settings, CABAC      : Yes
    Format settings, ReFrames   : 3 frames
    Codec ID                    : avc1
    Codec ID/Info               : Advanced Video Coding
    Duration                    : 2h 53mn
    Bit rate mode               : Variable
    Bit rate                    : 4 280 Kbps
    Maximum bit rate            : 5 500 Kbps
    Width                       : 1 280 pixels
    Height                      : 720 pixels
    Display aspect ratio        : 16:9
    Frame rate mode             : Variable
    Frame rate                  : 29.970 fps
    Minimum frame rate          : 0.447 fps
    Maximum frame rate          : 29.970 fps
    Color space                 : YUV
    Chroma subsampling          : 4:2:0
    Bit depth                   : 8 bits
    Scan type                   : Progressive
    Bits/(Pixel*Frame)          : 0.155
    Stream size                 : 5.17 GiB (93%)
    Audio #1
    Format                      : AAC
    Format/Info                 : Advanced Audio Codec
    Format profile              : LC
    Codec ID                    : 40
    Duration                    : 2h 53mn
    Bit rate                    : 93.5 Kbps
    Maximum bit rate            : 304 Kbps
    Channel(s)                  : 2 channels
    Channel positions           : Front: L R
    Sampling rate               : 48.0 KHz
    Compression mode            : Lossy
    Stream size                 : 116 MiB (2%)
    Audio #2
    Format                      : AAC
    Format profile              : LC
    Codec ID                    : 40
    Duration                    : 2h 50mn
    Source duration             : 2h 53mn
    Bit rate                    : 196 Kbps
    Maximum bit rate            : 199 Kbps
    Stream size                 : 239 MiB (4%)
    Source stream size          : 243 MiB (4%)
    Language                    : English
    Encoded date                : UTC 2015-03-06 01:52:32
    Text
    Format                      : EIA-608
    Muxing mode                 : SCTE 128 / DTVCC Transport
    Muxing mode, more info      : Muxed in Video #1
    Duration                    : 2h 53mn
    Bit rate mode               : Constant
    Stream size                 : 0.00 Byte (0%)
    Encoded stream size         : 0.00 Byte (0%)
  4. Frame rate mode : Variable
    VFR = Variable Frame Rate
    This means each frame isn't displayed for the same duration. ie. The FPS speeds up and slows down in sections. Timecodes control the display duration of frames. When you demux the video from the container, you lose those timecodes
    It's not possible to edit VFR in traditional NLE's like vegas which use a CFR timeline, it must be converted to "approximately" CFR. The conversion isn't perfect, and it might go slightly in and out of sync, but not as bad as what you probably have now
    If your goal is to keep the video as-is without re-encoding, you need to keep it VFR, but edit a "converted" CFR version of it in vegas. Then export the audio. It is possible to remux that version with timecodes and keep it VFR
  5. Originally Posted by poisondeathray View Post
    Hey, Thanks for your help on this,
    I was just reading the media info output and noticed 2 audio tracks.. which there is only one in the original, but the file i got the output from was the original, then i realised i accidentally overwritten the original MP4 when i was muxing earlier, 1 is the edited audio track and the other is the original... So i played the MP4 and switched the audio channels, and noticed they were perfectly in sync, which makes sense now you have told me about VFR,
    Is there a way to remove an audio track from an MP4 without muxing and loosing the VFR info? If i can do thats i will leave it as is and that will have to do.
  6. Originally Posted by B1ueChr1s View Post
    ffmpeg should be able to do it and copy the timecodes over with -map to specify the wanted streams. Double check the stream numbers are correct (the mediainfo stream numbering doesn't always correspond to ffmpeg stream numbering
    Usually, 0:0 will be the 1st video, 0:1 will be 1st audio, 0:2 will be 2nd audio.
    So if you wanted to keep the video and 2nd audio:
    ffmpeg -i input.mp4 -map 0:0 -map 0:2 -c:v copy -c:a copy -movflags faststart output.mp4
    To be clear, the input mp4 will remain (it won't be overwritten), but the video and audio #2 will be copied over into a new mp4 container with the timecodes
    There are other utilies for deal with VFR streams as well, like mp4fpsmod
  7. Originally Posted by poisondeathray View Post
    That worked perfectly, Thank you for all your help.
    Chris.
  8. Cheers
    It is possible to do what you had planned, as described by using a "CFR" version of that video imported into vegas to use as visual cues. It won't be perfect - not suitable for something that requires perfect timing - but it will be close
    The converted CFR version inserts frames approximately where were dropped in the first place (frames are usually dropped in VFR video) . So you do your audio manipulations in vegas as you normally would, using the CFR 29.97 version as a visual guide. Export audio as usual, then mux into the MP4 container with timecodes
